mtnmankev
- Jun 10, 2014
- Ash Fork, Arizona
- Kevin
- K10, C20
- 383 Stroker, 350
On my 84 K10, I turn on park lights, and all four corners of the truck light as they should.
Turn park lights off, turn the key to ON position, and flip the turn signal lever for right turn, both the right front turn bulb flashes and the corner marker light flashes with it.
Turn park lights on, key on, right turn position, the RF bulb flashes and the corner marker bulb goes out as the turn bulb flashes.
Go for left turn, I have to jiggle the turn signal switch lever a little, and get a solid glow from the dash indicator bulb, but no bulbs light up front or rear, and no left rear brake light.
I tried different flashers, get the same result.
I did have a problem for a couple years where the ground tab from the LF bulb socket had disappeared, and all the time the lights were on I had a solid glow from the left turn dash indicator bulb. I wonder if that damaged my turn signal switch ......
And how did the corner marker light bulb get involved with the turn signal ? It should be a separate circuit.
