Steering Wheel Too Close '84 C-10
Ronno6
South Mississippi
Ron
I find the steering wheel in my '84 C-10 to be uncomfortably close to my chest, even with the seat all the way back.
I can't imagine how shorter drivers even fit behind the wheel........
Short of cutting down or replacing the steering column with an aftermarket part, what can I do to increase the clearance??
Is there a flatter wheel that I can use?
My C-10 has a tilt column..........
brooksman9
Olive Branch, MS
Patrick
Silverado & Custom Deluxe
350 & 305
I dont know if it is flatter but I use one from a second gen Camaro on both my squares. They are a little smaller in diameter and seem very comfortable to me. I did try an aftermarket one but it was just too small for the truck. It does work well in my Camaro though.
Chevy 88
Canada
f7t6
GMC
You could get a sternum buster steering wheel.
Frankenchevy
Proverbs 16:18
USA
Square
CUCV
Small
Are you far above average either height or circumference? I am 6’1” 225 pounds and fit easily in my single cab without a tilt wheel. My waist is 33 inches though, so that helps.
Ronno6
South Mississippi
Ron
I s'pose I am.....6'4" and currently 265...but it was close even when I was thinner...
Ronno6
South Mississippi
Ron
Do those require hub adapters or do they bolt right on??
I've never tried this but this is what I would try. Collapse the steering shaft under the hood and make a relocation bracket to mount the column further under the dash,or relocate the factory mounting clamp. The relocation bracket is probably as simple as a flat plate with 4 holes drilled in it.Mount the column further forward. 2nd try. Gm columns are very interchangeable I'd look at a column from an s10 real hard. You should have a clamp similiar to this,see if you can just relocate it's position on the column,and shorten the under hood double d shaft it just pushes in when you melt the plastic pins. And look at steering wheels with no dish
Moderator Administrator
This is a fact, Squares don't like us bigger taller people. I wish there was a magic fix for it, like a shorter column swap.
Is your seat relatively new? I recently replaced the seat foam and seat cover on my ‘75 GMC, and the steering wheel clearance is now really tight (I’m only about 5’8” and 185 lbs). I’ve tilted the steering wheel up some and that helps, but that brand new foam is much different than the old worn seat.
Ronno6
South Mississippi
Ron
Nope...it is original. Gonna have it reupholstered. Maybe they can do something to help the situation......
SethVo
Detroit
Seth
I had a similar issues and was able to loosen the bracket under dash alone with the others along the column out to the steering box and get about another 1/4 to 1/2 in. Helped some for me.
I’ve also seen some seat relocation brackets, but I’m not sure how they work. My seatback is almost touching the back of the cab, so there isn’t much space to move it back.
legopnuematic
Licensed Junk Dealer
MO
Spencer
I've never messed with them but corvettes and some other GMs had telescopic columns. Not sure if they would end up shorter or longer than a truck column.
bajadiver
