Steering Stabilizer
Boone83K10
Boone, NC
Benjamin
Guys mine exploded...
I bought a new one, its a single stabilizer.
I need the torque specs for the castle bolt at the steering arm and the axle side mounting bolt.
skysurfer
west coast
1989 Suburban
V2500
5.7/TH400/NP241C
That's not really a torque-spec critical part, just tighten it down with a medium bit of oomph and call it good. Use some blue Loctight if you have it.
MadOgre
NA
NA
NA
NA
NA
55-65 ft lbs should be good same as a shock absorber
firebane
Calgary, AB
Curtis
It should have a cotter key so tighten it down till you can insert key.
Tight enough for it to not fall off, yet not so tight as to strip the threads.
:anitoof:
Boone83K10
Boone, NC
Benjamin
Rusted through..it spewed all the fluid every where and I couldnt turn without it binding. I tightened the castle to 35 then inserted the court pin. Axle side was to 55.
alwaysbroken
