Steering stabilizer. How the hell do I get the old one off?
MisterB
Northwest
AJ
GMC K2500 4X4
I bought a new rancho one. I'm trying to get the stock one off. I got the bolt off this side, and the bolt off the passenger side. The stabilizer shock lifts up easily away from the passenger side, but the driver side still is stuck on after removing the nut. How do I get the rest off? I've tried pounding that threaded end through, but it won't budge
Sent from my SM-N975U1 using Tapatalk
MisterB
Northwest
AJ
GMC K2500 4X4
Dutch Rutter
Independence, Or
Joshua
I second the BFH. I recently did mine. Added some heat and beat the hell out of it with a 4lb short handle sledge. Took a while and was suprised when it finally knocked out.
It might help if you can put a piece of wood behind the bar to keep it from flexing and absorbing the hit.
Vbb199
B-rate Hillbilly Customs
Salisbury NC
Vince
89 Suburban R1500, 79 C10
Thanks! That link doesn't work though. Is it a tie rod separator set?
It's from HF
Sent from my SM-G965U using Tapatalk
Vbb199
Salisbury NC
Vince
Very similar to a 10 bolt steering arm.....
BFH
Vbb199
Salisbury NC
Vince
Works pretty good for HF tooling... I've abused it many times
MisterB
Northwest
AJ
GMC K2500 4X4
I went and bought every tool recommended, but the only thing that did the trick was this little beast. When it popped, it was so loud, I thought the tool had broken, but it was just the stabilizer finally breaking loose
Vbb199
Salisbury NC
Vince
For 15$ you'd think it would just snap, it's stout
MrMarty51
Eastern Montana
Martin
A pry bar between the pivot of the rod and the drag link, pry for all its worth then with a larger size hammer, three or four pounder, beat the piss out of the drag link where the stud goes through. Just be careful that when it pops free You dont hit Your arm or hand on some poor unsuspecting portion of the truck.
This method has always worked for anything with a taper component that I have had to disassemble. ie rods, ball joints, steering knuckles, You name it.
idahovette
Weiser Idaho
Perry
K20-K10
Easy, Marty !!!! Remember "the heart"!!!
Chevyguy
Eugene,OR
Clayton
V20
5.7 Litre
PB Blaster helps too.
Clayton
Sent from my LM-V350 using Tapatalk
Vbb199
Salisbury NC
Vince
Clayton
PB blaster and a BFH? [emoji1787]
ali_c20
Austria
Alexander
C20, K5
BFH and some muscle.
metro247
