Steering Geometry Question
Vbb199
B-rate Hillbilly Customs
Salisbury NC
Vince
89 Suburban R1500, 79 C10, 99 Silverado
Even a little bit of firewall surgery would be less complicated than re-engineering the steering geometry.
Looks like this is gonna be winner after looking at this thing some more. I got dimensions for the oil pan I will be using (a modified 4x4 3.5L pan) and it turns out that its never going to fit next to the diff anyways. The whole driveline is gonna have to go backwards and maybe up 2 or 3 inches which will clear up the problem
@bucket is right, the idler and pitman arms must be exactly parallel with each other all the way through the arc of the steering or it'll bind. The remote filter setup and a little massaging to the idler bracket will be the ticket.
idahovette
Firefighter
Weiser Idaho
Perry
K20-K10
You boys, @bucket and @TotalyHucked aren't living in the real world. So many of the idler arms installed on many different rigs were mounted in slotted holes, that is there was up and down movement where it attached. There IS some leeway......I wasn't talking about inches and I DID say to keep the plane equal from side to side. You're NOT changing the swing , just where it swings from. Also NOT ALL idler arms were exact in measurements or any replacement part for that matter, right? Doesn't seem to make any difference now anyway, Vince has got it figured out, SO????..........GET OFF MY LAWN!!!!! I'll add, I am NOT a newbee when it comes to front suspension
Simmer down newb.
Moderator
It's the inboard/outboard part of the relocation that I was trying to emphasize. But I will say this... if you say it will be fine, then I'm inclined to believe it.
Vbb199
Salisbury NC
Vince
Now I just want to move the damn thing for shiggles even though it wont even be in the way after I move the motor back lol
Old Guy Bill
KY
Bill
Just a side note on this topic...
In the old days all circle track guys used Ackerman Steering.
We changed the length of the idler arm to get the right front tire to turn just a few more degrees than the left.
It would make the car turn way better to the left... :)
Vbb199
Salisbury NC
Vince
This steering situation has got to be one of the more confusing and controversial topics on this forum , has to be up there with "vortex" heads and heat crossovers
You're not wrong, there is leeway. But most people don't understand the minute intricacies of steering. I've done lots of steering and suspension work on many different types of race cars. For his purpose and what he was wanting to do, I saw more issues arising than being solved, so I just kept it simple
bigy8s
