Steering column wiring
hunters628
Ellensburg Washington
Hunter
I got a deal on a 81-82 tilt column that I just couldn’t pass. Only problem is it’s missing the shifter arm and someone cut the wiring harness off and mounted a under dash ignition. So I’m guessing I need a new ignition which is no big deal. The issue I have is finding the wiring. Never had one of these apart so I’m not sure how it works. It has a turn signal switch with cruise that I would like to keep for when I add it later. Are there any sources for the column harness or will I have to attempt to make a new one
Termite_Delight
Lanark Ontario Canada
K2500 K2500
350 L33
Pictures? There is no ignition wiring in the column... if wires were cut, they would be for signals, horn, hazards ect.
hunters628
Hunter
Don’t have a picture at the moment. I can get one when I’m home sunday. The harness that domes out of the column, that has turn horn and all that stuff, is cut off right where it comes out of the column. There are no wires or connectors coming out of the column to connect to the body harness.
