Steering column compatibility
ww.ebay.com/itm/193331586287?_skw=GM+Steering+Column+Lock+Plate&itmmeta=01KGC01PZ1B6TE4EQVA1W6WDGF&hash=item2d0375e4ef:g:WP0AAOSwgNZeOXcJ&itmprp=enc%3AAQALAAABAO7PUuNWmJ%2B%2BUShgI9tQz%2Fp3hAzV1W3G7%2FfMmsIjVIcOh0Hnw3VDcP%2BWFdbk5rYJ5whZIIzQsGS9hO7x1T9aq6QZm%2FKCJnsR7fy1od6iGJS1nb8aImEooanNHftOR9LUMbudYV1RlWAy%2Fwfm0DYywH3T3nXDnfYZvzU2G%2BiPnh0JFOKxubRUvF%2BCZRiC92nKaVxcoPgeXUp6ZuLH5m4fvG%2FIP3qDOoDkKeg2rUC8sCLdS1VWs4KuWyrWYo9buryJLLa2B0GGKJyzchZKW7Xw%2FLRr2f6grwmJY6uFJjBFumIhbWxGUv6a%2BswMYtkGJllT56L%2BtxnxbnABnUWCNodGbMw%3D%7Ctkp%3ABk9SR9bvhoCDZw
This one was used for Caddie. Crude' Excellance'...
The bearing and race kits are affordable. Try Rock A?
Lil' paint, new spring. New turn switch...
You got this.
Cut your lock plate down to this or leave one or two of the long outer plate tines, so the wheel cannot make a full rotation when locked?
You can hack it up pretty small and it will work to hold the spring and lock ring.
Is that the lock plate in the 2003 + gmt800 without a steering wheel lock?
RanchWelder
Earth
Blazer
350ci
It has a couple older part numbers.
  • Part Number:26049186
  • Replaces:19133709, 26113917
According to: https://www.chevroletpartsdirect.co...nal-switch-cancel-cam-position-plate-26049186
If you search eBy for those numbers, instead of the one I pictured in my previous post, you get a broad range of vehicles it fits.
in the compatibility list and a cheaper price. All sorts of cars and trucks, 2017-1990 Cavalier.
Verify the nut size for the wheel.
If I recall some are 1/2-20 and others 9/16-18?
https://www.ebay.com/itm/365907421471?_skw=19133709&itmmeta=01KGGEQD7B4THXNJH713J0RESV&hash=item5531c8291f:g:TGsAAeSwhERo5Ov3&itmprp=enc:AQALAAAA4O7PUuNWmJ++UShgI9tQz/oBXamQ3KQoc5puxcNNlTtY5BUyDb/LW9uExf9Omo8c5mMdoH4HeDR2oo32RZUV5jrogF3mhJPC6+Nzaswp8dM5EfinYve0j388h9MSrr4EZMajcECG3fm+wRNpOo7M3rj4FwCEfheqHDTEoOBkm3t5nz5MO2V0if9dERL5FJPHnIKrAxzuhai3lBVBdjtHewVxR9RTAmGqQbzRdzfD6V9qYoPZhhvtgFdOo4hTIQDkx1v8aDbjUboLlzpBhJhj5eWrO/zlyFNVQbvz2AU2do0/|tkp:BFBM4NPdjoRn
My GMT400 column is 600 miles away Auroragirl, or I'de ship it for you.
Nborden88
