Steering box differences
Griff
Thunder Bay
Griffin
K1500
350 sbc
Hey guys
Sorry if this has been posted before, but I have 2 questions. I have a 79 and I’m wondering the differences between the 73-87 steering boxes. Local parts store says only 77-79 will fit my truck but the only difference I can see (from online details) between mine and the 80+ is the hose threads. Mine are imperial and the newer ones are metric. Buddy of mine has a box that he’d give me for a case of beer off an 83, and the store wants $250 something for a reman unit.
My sector shaft moves up and down into the case when I turn one way and PO had the adjustment screw bottomed out. It’s my assumption that the gears/bearings etc are probably shot anyway and I should just get something else instead of rebuilding my current one. Any advice would be appreciated. If it’s simply a matter of changing hoses to fit the 83 box I’d much rather do that. From what I’ve read on here reman units are pretty hit or miss. Thanks
Griff
Yep, the newer box will have metric fittings that use an o-ring. There's actually adapters out there so you don't even have to mess with changing hoses.
Griff
Thunder Bay
Griffin
K1500
350 sbc
Awesome thank you! I might just get the whole pump off him. Either way it’s cheaper than 250!
Just keep in mind, 4x4 boxes have a different sector shaft than a 2wd box.
75gmck25
Northern Virginia
Bruce
FenderBanger
