Starting Issues
Mattitudx
North Carolina
Matthew
Ok so in a bit of a bind. I had replaced the both headgaskets and the engine was running pretty good. was a b**** to start sometimes. Well I ensured the distr was set correct to TDC. Ensure no binds in fuel line. Ended up replacing the stock Carb cause it seemed to be flooding the spark plugs, and sometimes would spit fuel. Carb that I replaced it with was a 1405 Edelbrock. With the edelbrock adapter plate to mount onto the intake. I had to remove the EGR valve that was on the valve cover and sealed it. Prior to replacing the head gasket there was nothing connected to the EGR. Might be something im overlooking, might not be. Any suggestions would be appreciated. Thanks
1982 Chevy Scottsdale K10 P/U 4x4 305 V8
chevyman75
pa
nate
are you sure you have distributor on tdc (top dead center) compression and not exhaust?
82k20
westmoreland tn
jerry barnard
k20
350 modified
make sure it was set to tdc on #1 if the rotor button is at that cylinder i would check the plug wires routing on the rotar i know how that sounds but i pulled my hair out with this problem on my truck it was out 180 if your wired correctly then i would check fire at the plug if ya have fire at the plug then check fuel delivery to make sure its getting fuel firing order is 18436572 hope this helps ya i know how it feels ta have one thats actin like that they can be a pain
(corrected the firing order HRPC)
MrMarty51
Eastern Montana
Martin
UH, dont forget the 6 that`s between the 3 and the five. LOL
EGR valve on the valve cover ???
Me too, Curious about this EGR Valve in the Valve Cover? :shrug:
82k20
westmoreland tn
jerry barnard
k20
350 modified
to mr marty 51
yeah sorry bout that just saw the problem my 6 must not have typed ya know how keypads can be or i just simply missed it never heard of egr in valve cover
chengny
I think he is saying that, in order to pull the RH valve cover, it is necessary to first remove the EGR valve. It's a real close fit and when trying to pull the cover, you either hit the valves on the inside or the EGR valve on the lower lip:
82k20
westmoreland tn
jerry barnard
k20
350 modified
to chengny okay i see what your sayin it looks like it would hit i just misunderstood but i see now
MrMarty51
Eastern Montana
Martin
to mr marty 51
:happy175::happy175::happy175: I unnerstand. I leik to blahm My mizpellig on duh kley bloards. :happy175::happy175::happy175:
OHHHH YEAH, I can see that now, about the EGR valve.
82k20
westmoreland tn
jerry barnard
k20
350 modified
it happens lol.
87Chevy520AZ
