Starting Issues TBI 350
Jake292
Fort Worth, TX
Jake
r10
350 efi, 700r4
The past few days my truck has had some issues starting. When I first turn the key it fires right up but within a few seconds it sputters and dies; it doesn't matter how much gas I give it. Then when I try to start it again it has to crank for a while and, with the throttle is half way open, it will begin to fire and it clears the fouled plugs and runs fine.
For a while it has died when under an load at idle for a few minutes, like in drive at a stop light. I have been just power breaking it a little bit and it hardly ever dies on me.
Do you think it is flooding with too much fuel? That's what it sounds like to me.
skysurfer
west coast
1989 Suburban
V2500
5.7/TH400/NP241C
lol, I was thinking just the opposite and that the fuel pump is going bad. This is where a pressure gauge mounted in the fuel line comes in handy.
MrMarty51
Eastern Montana
Martin
My answer to everything. O2 sensor. LOL
Jake292
Fort Worth, TX
Jake
r10
350 efi, 700r4
it seems more to me that it is running out of fuel. The O2 Sensor is new. Will pull codes this afternoon.
We got to whip up a vendor on here that sells an affordable fuel pressure tester just for these TBI trucks. :Angry:
Might be that damn rubber hose on the pump in the tank.
BTW, if you wind up doing anything with the fuel pump keep this place in mind:
http://www.tanks-to-pans.com/
Pull a few plugs and see what they look like.
Jake292
Fort Worth, TX
Jake
r10
350 efi, 700r4
Attached is the Tunerpro file, if it helps.
The only error codes that I saw was high map and EST. if the map sensor is still under warranty, I will replace it.
I found parts to do an inline fuel gauge that adds up to 25 bucks, going to do it this week.
Jake292
Fort Worth, TX
Jake
r10
350 efi, 700r4
it wont let me upload the file like it used to :wtf:
Jims86
Patterson,Ca
K10 Suburban Silverado
5.7 TBI
High voltage is usually a vac leak, or looowwwww.
Check the reference voltage supply at pin C of the MAP sensor (gray wire typically). Measure voltage between pin A (ground) and Pin C (+5 V ref) with a DVM. It should be right around 5 Vdc. With Key on engine off the MAP voltage (Pin B, light green wire typically) should read around 4.8 to 4.9 volts. If it reads the same as pin C the sensor is probably is history. Also check ground reference pin A. With everything off, measure resistance between Pin A and electrical ground (stud next thermostat). It should be fractional ohms.
Another functional check – with engine idling MAP output voltage (depending on idle vacuum) should be in the neighborhood of 1.2 to 2.0 volts. If it is stuck at 5 volts, check grounds and most likely MAP sensor is history.
dob555
