Starter mounting bolt pattern
WFarm
Central Virginia
K5 Blazer
My 1987 R1500 with 350tbi and TH700 Auto has a starter mounted with staggered bolts. It also appears to have an unused tapped bolt hole for mounting the starter with in-line bolts? Can starters using either mounting arrangement be used?
Nope. The block is drilled for use with the straight starter pattern, but that is for use with a 153 tooth flywheel used in cars. Your flywheel (or flexplate) is a 168 tooth and requires the starter with staggered mounting pattern.
However, there are aftermarket "mini" starters that have a straight mounting pattern, but there is two pairs of mounting holes. Those are designed to work with both size flywheels.
WFarm
Central Virginia
K5 Blazer
Makes sense Bucket. Thank you!
jbwhitford
