El Diablo
- Dec 26, 2014
- United Arab Emirates, Middle East
- Gair
- K10
- 350ci
Hi and thanks for reading...
I have a 1973 K10 with a 350, TH350. She's a project - body off resto.
I wanted to fire the engine just to make sure it DOES fire. Sorted some basic wiring. Solenoid noise only. Bit more investigation. Starter motor is 'Staggered' bolt pattern with a 14", 168 tooth flexplate... but only one bolt is holding it in place, plus a dodgey front bracket (non-standard).
I removed the starter motor and the block has two holes plus a molded 'dimple' it look slike, for a replacement starter motor. This neither a linear NOR staggered bolt pattern. What starter motor can I fit to this? Is this a really old block? Is it not a 350? I know the Small and Big block should have the same starter motor options so this one has me stumped? even checked for all types of starter motors (Chevy) on a Google Image Search, but I can't find anything that would have this style of mounting pattern?
I'll try to attach some pics. As you can see in one, the staggered pattern doesn't even have a hole in the block to mount to. The single bolt has (a long time ago by looks) broken some of the casting away from the nose, and the bolt itself was bent - which makes sense.
Any ideas from the GM Gurus????? Would love to stick a mini-hi torque in there - if I could find one that fits?
Cheers
Cheers
