SRW to DRW
SA Fan
Johannesburg, South Africa
Marius
Hi folks. I'm sure this info is somewhere on this forum but I have no luck finding it. I'm lucky though to own a 78 K20 as well as a 85 K30. I'd like to do a DRW Dooley with the fat fender conversion on either one of them. I have a few questions.
1.Is the chassis on the DRW Dooley also narrower in the back like the chassis cab DRW or is it the same as a SRW?
2. Are the front hub spacers interchangeable between the K20 (Dana 44HD) and the K30 (Dana 60)?
3. Is the SRW rear diff the same width as the DRW Dooley, if not by how much?
4. Any other pitfalls I should watch out for?
Where can I find the following at good deals....
1. A set of the used front hub spacers
2. A set of used dually wheels
3. A set of the rear dually fenders
I'm located on the other side of the big pond in South Africa but do have a shipping guy in Florida who does monthly shipments for me of American car parts. He liaise, orders and pays for it on my behalf which eliminates all risk for the seller. Being this side unfortunately limits me to what one can find on the internet. I was hoping for someone who might have these parts lying around in a shed somewhere or can put me in contact with a local junkyard that you are familiar with. This conversion is particularly difficult to accomplish over here due to the fact that we never had the Dooleys available in SA, only the SRW.
Any assistance is greatly appreciated.
Thanks in advance!
CSFJ
1) no. They used a narrower spring spacing on the 1 ton trucks to get a little extra clearance for the duals
2) no.d44 and d60 are 2 entirely different animals. If you get them side by side and pull the front wheel from each, you'll understand the size difference
3) no. The rear axle that chevy put in the dually pickups was a dana70. It is considerably wider than the 14 bolt full floater that they used under the srw trucks. (Somewhere around 6-8" give or take, iirc). They did use some 14 bolt dual axles under the cab and chassis trucks, but those are a lot narrower.
4) you might need to adjust driveshaft length also
87silveradok20
Ohio
Levi
Silverado k20
1) no. They used a narrower spring pack on the 1 ton trucks to get a little extra clearance for the duals
It wasn’t a narrower spring pack wasn’t it just springs mounted closer to the frame
CSFJ
You might be right. I've never sat down with a tape to figure out what exactly they moved around to fit the duals. I know the spacing is different when it comes to the axle perches, so that makes more sense. I probably shouldn't answer questions that early in the day, lol
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Spring hangers are closer to the frame. DRW hangers are different.
hirschdalechevy
norcal
rich
k-30
In the 70's all 1 tons were narrow spring hanger dually and single. My crew cab is not a dually but it has the narrow hanger's.I am not sure about the 85 but a tape will tell you.
Jrgunn5150
Questionable methods
Ionia Mi
J.R.
6.slow
Correct, spring perches are inboard on 1 tons.
CSFJ
? Inboard of what? They're still outside the frame rails. They're closer to the frame, but still on the outside.
Jrgunn5150
Ionia Mi
J.R.
6.slow
Just inboard from the 1/2, 3/4 ton location.
Craig 85
Nashville, TN
454/TH-400/NP205
Here's a shot of my K30 when the bed was off. You can see the springs are closer to the frame and the shocks mount on the inside of the frame.
Also, here's a link to a company (Arrowcraft) that makes dually conversions. They've been around for over 30 years. Unfortunately, they don't make squarebody fenders anymore. Unlimited Products makes square body dually fenders. Part # GM-201R/L.
http://www.arrowcraft.com/products.php#fenders
http://www.up22.com/chevytruck.htm#GM-201R/L
ajd89
Central Michigan
andrew
Ive never seen those links before good stuff there!
ajd89
Central Michigan
andrew
Just called 300 bucks for the front spacers for a k20. But My question is how are you gonna reach the lock out?
ajd89
Central Michigan
andrew
Skinny fingers lol.
I geuss i wasnt really thinking the lockout sticks out quite a bit on a 10 bolt maybe it would be close to flush with the rim if you used adapters
btrain04
