Square covers
dhamp
Atlanta Area, GA
Derek
R-10 Custom Deluxe
For those looking to buy a cover for their square, I thought it would be a good place for people to give feedback on the ones they have used.
I just trashed my LMC mid-grade (3000 series) cover.
http://www.lmctruck.com/icatalog/cc/full.aspx?Page=93
I wouldn't really recommend it. It did not have any longevity claim with it, so it was an experimental move. At about the 2-1/2 year mark, the backing started leaving dust all over the truck so I'd have to hit it with the California Duster before driving it anywhere. Also, the fit wasn't good. When the wind got up, it would flap around and it damaged the paint where the a-pillar meets the roof. I eventually ended up using bungee cords to hook at the bottom of the fender on each side and stretched across the cowl. That kept it from flapping around, but the damage was done by that point. There was also water pooled up over the bed where it would sink from being too big and having the weight of the water. Rainwater would also pool under the cover in the fold where it curves under the rear bumper. I never figured out how though. Here's a pic of the LMC (tan) cover attached. You can see loose it is and how it hangs at the back bumper.
A few weeks ago, I ordered a new cover by Empire Covers labelled "Budge". It's a 5-year cover in gray. The fit is snug enough where it won't flap around and damage the paint, nor pool over the bed of the truck. So far, I haven't found any water pooling anywhere else either. Total cost shipped to my door was $106. The attached pic with the gray cover is the Empire Cover
robert8096
Goose Creek SC
Robert
Got the California car cover and its doing well but way more then the price above.
Green79Scottsdale
G.R. - MI
Bob
I will have to do some investigating on my cover. It is a fitted cover, specifically for a long bed square body. It has been on the truck for the better part of 15 years, albeit inside a barn. It is awesome for what I need, and I will cry if I ever need to stop using it. I don't know what brand or how much, that's what I need to figure out. And get some pics too.
dhamp
Atlanta Area, GA
Derek
R-10 Custom Deluxe
How long have you had it? Approximately how much was it? Do you have problems with it caving into the bed from rain water? I got back home last night and apparently we had a good soak while I was gone this weekend. The bed was full of water and the cover was sitting on the bottom of the bed. I don't know how to curb this without putting a big beach ball or something in the bed to keep from having a low spot like you do with swimming pool covers.
skysurfer
west coast
1989 Suburban
V2500
5.7/TH400/NP241C
Boat covers use an expandable pole to hold up the middle where it sags. You can either install a grommet in your cover and use a tipped pole, or install a snap in the cover and use the snap-equipped pole.
http://www.firstchoicemarine.com/p-...cover-support-pole-adjusts-from-30-to-60.aspx
http://www.harborfreight.com/103-piece-1-2-half-inch-grommet-installation-kit-30037.html
They also make flexible fiberglass rods that could be attached to the stake bed holes to form a bow across the bed. Here's a cheaper way to do something similar.
[yt]rSnJl88h45M[/yt]
dhamp
Atlanta Area, GA
Derek
R-10 Custom Deluxe
I might have to look at something similar to this if the beach ball method doesn't work out. Thanks!
robert8096
Goose Creek SC
Robert
Almost a year, about 350.00 and I have an old tonneau cover that I sit on the bed to keep it from sagging.
dhamp
Atlanta Area, GA
Derek
R-10 Custom Deluxe
didn't think of that. That would be ideal. $350 is some serious grip, but I do like the way it fits. It looks pretty snug. I figured if I get at least 3-4 years out of a $100 cover, I'd get 12 years worth of protection out of the deal. If the California Cover lasts over 12 years, then I'd be on the losing end. I just don't see a cover lasting in the elements that long.
robert8096
Goose Creek SC
Robert
I have had a few California covers and none have let me down.
dhamp
Atlanta Area, GA
Derek
R-10 Custom Deluxe
I hear ya. I don't doubt they're good covers either. I just question one lasting 10-12 years unless someone one has seen one do that. I also plan to have it garage within the next 2-3 years, thus eliminating the need for a cover so I didn't want to spend more than I really had to.
Of course, I thought I'd have the garage built within 3 years of buying the first cover too and that hasn't happened.
You can also build a V shaped cage out of PVC pipe to stick in the bed to keep the middle of the bed cover supported. I also recommend spraying them down every year or 2 with a good coat of Thompsons waterseal or equivalent.
Sent from my iPhone using Tapatalk - now Free
dhamp
Atlanta Area, GA
Derek
R-10 Custom Deluxe
We got some fairly decent showers yesterday and last night, and there was no pooling this morning when I left. Apparently there was some monsoon type rain that came thru this weekend and it has enough speed and volume to force the cover into the bed. I think I'll just keep an eye on it and see how often it's even an issue. If we get that kind of rain 2 or 3x a year, I'm fine with it as it. If it's going to me more than that, I'll probably do the pvc frame in the stake pockets with 3 cross members for support. That combined with the fact I always park it facing up hill should do the trick.
dhamp
Atlanta Area, GA
Derek
R-10 Custom Deluxe
Got any pics from the side or back? I'd like to see the fit on the bed.
dhamp
Atlanta Area, GA
Derek
R-10 Custom Deluxe
