Spray in bed liner
seabee
South Carolina
Lee
R10
Anyone have pics of spray in bed liner in there truck ? My 1987 has slide in that dealer installed 1987 . Thinking about having a spray in liner done . My 2005 Z71 has a rhino liner . But never seen a square body with spray in bed liner
87silveradok20
Ohio
Levi
Silverado k20
Here's mine in my 87
Craig 85
Nashville, TN
Craig
K30 SRW
454/TH-400/NP205
I have Line-X in my 2016 Ram and I'm really happy with it. On my K30, I'm going to spray the bed and on the top of the bed rails, but stop before it rounds over to the quarter panels so you don't see it from the side.
smoothandlow84
I'd rather be draggin' frame
Steve
1500 r10 pavement scraper
Here's mine...after smoothing out the bed and building the tunnel for the rear bags and bridge.
I went with a local spray in liner company called "UNIVERSAL" bedliners. I ended up having them spray a thicker coat, and went under the side rails.
On my Duramax I had Line-x, which faded after the first year and was imo overpriced for the thin layer that they applied. Line-x for a 1/2 standard length bed was $535.....Universal which hasn't faded in the last two years and has been applied twice as thick was $250 and was completely prepped and sprayed i. Under 2 hours. The Line- x crew took over 6 hours.....maybe that's why they overcharged me...lol
CSFJ
Damn. I wish they had a Universal installer up here. That sounds awesome.
Silverado81
Lee
c 10
Here is the LineX in my '81. I had it done back in 2000. It needs a good scrubbing, but still looks decent.
74 Shortbed
I like the looks of that bed..
bucata206
Silverdale WA
Anthony
Here is the LineX in my 73 stepside
Did you replace the bed floor on your bed with diamond plate metal?
1973c10
Don
Yes I did
I redid the wood floor first in the first bed I was going to use
then I picked up a bed that was straighter and didn't want to switch it all over
and knew I was doing bed liner so I just put diamond plate in
bucata206
Silverdale WA
Anthony
Yes I did
I actually like that idea. The bed on my truck is rusted so I'm looking for a replacement.
Sent from my SM-G900V using Tapatalk
1973c10
Don
If I ever want to put the wood back in I can pull 8 bolts and slide the diamond plate out
74 Shortbed
What did you use along the sides on the bottom against the diamond plate?, don't look factory but it looks nice and clean, I'd like to do something like that with mine..
1973c10
Don
It just slid under the factory edge of the box where the first row of wood would have been
