Speedometer off
Red Rex
Middle Ga
K 1500 4 WD shortbed
My speedometer reads 5 mph faster than my gps.
208c transfer case original equipment
Th350 transmission replaced 700r4
3.08 gears original equipment
30 inch tires
I have changed the speedometer with a junkyard part
No adapter on the transfer case. It has a black plastic gear in the housing.
How can I tell what gear in the housing I need and where might I get it or do I need to change the speedometer?
C10MixMaster
Kingman AZ
Ben
C10 BIG10
ZZ4 350
30 inch tires
You dont need to change the speedometer. You need to change the gears.
here's a link to a similar post that might help https://www.gmsquarebody.com/threads/np208-speedo-driven-gear-needed.20778/
Red Rex
Middle Ga
Appreciate the information and post!
LateOnTheBrakes
5.3-Swapped 86 CUCV
Virginia
Joshua
CUCV
What gears did you end up going with? My truck is a mix of 4.3L V6 and CUCV. I don't know which of the two my transfer case came out of. What I do know is the V6 should have come with 3.73 rear gears and my truck has 3.08 in the back. My speedometer reads about 35mph when I'm going over 50mph.
Todd Lemon
