Sparying high build primer bad texture
86chevyk20
Buffalo
Liam
This is my first time using a spray gun and I'm havin a bit of trouble. I'm using finish 1 primer and a harbor fright gun. I mixed it correct and have my air at 50 psi at compressed and 30 psi at gun. The primer texture is like The wall of a house , smooth but textured. What am I doing wrong isn't high build sopose to go on really smooth?? It takes me like 3 slow passes to cover a spot. Pls help. Tip size is 1.4
crazy4offroad
Equal Opportunity Destroyer
West BY-GOD Virginia
K-10
350/SM465/NP205
Mix in less air, and check your pressure drop at the gun when you squeeze the trigger. How long is the air hose you're using? Longer hose has a sharper pressure drop. Also what kind of gun is it? Syphon feed or gravity feed?
86chevyk20
Buffalo
Liam
It's a maybe 15 20 foot hose. Its a gravity gun it's the $20 from harbor fright. I got the compressor regulator at 50 psi and he gun reg set at 30
Thin out the primer just a bit. I used to use those Harbor Freight guns all the time to shoot primer, they work fine and can produce a good finish. It's likely just the primer you are using.
Stickman
