Spark plugs for 87 350 tbi
Moderator Administrator
Cheapes bid is how the MT. D.O.T. purchases parts.
They had a run of them bosch plugs. The 427 Gas dump trucks would get so hot, it would blow the porcelan right off the metal hex head.
2 plugs I always avoid, Bosch and Champion. Believe it or not, Motorcraft plugs even work well in Old School, non computer controlled small blocks with a 1 step down in what the book calls for in temp. Running a cool Motorcraft plug worked great for high performance. If you had a cylinder that was consistantly getting a carbon fouled and you KNEW it wasn't a bad wire or bad spot on the dizzy cap, then step that one cylinder up to the hotter plug that book called for. I usually had issues with cyl #7 and ran a different plug.
MrMarty51
Eastern Montana
Martin
2 plugs I always avoid, Bosch and Champion. Believe it or not, Motorcraft plugs even work well in Old School, non computer controlled small blocks with a 1 step down in what the book calls for in temp. Running a cool Motorcraft plug worked great for high performance. If you had a cylinder that was consistantly getting a carbon fouled and you KNEW it was a bad wire or bad spot on the dizzy cap, then step that one cylinder up to the hotter plug that book called for. I usually had issues with cyl #7 and ran a different plug.
DOT never had a run of MotorCraft plugs, the must have been too expensive. :roflbow:
I guess I had never tried Motorcraft plugs in any of My GM vehicles, I always stayed with the AC/Delco plugs and parts.
I wonder if it would have done the same, with Your number seven cylinder, if You would have tried a AC plug in there instead of a motorcraft, maby AC/Delco does`nt make stepped plugs like that, IDK, I never had to make an exception for a cylinder or two.
That sounds like some BS. You can check RockAuto.com and get our 5% discount and no sales tax if you're not in a hurry and have about 3-4 days to wait.
MrMarty51
Eastern Montana
Martin
Rock Auto is good.
I`m not having problems with needing one or two plugs hotter than the others so, IDK if AC makes stepped plugs.
My 1976 FLH Harley, Shovel Head engine, I would run the rear cylinder with a cooler plug but, I used NGKs in that.
Rear cylinder with a cooler plug to allow that cylinder to run just slightly cooler as, the heat from the front cylinder would make the rear run a bit warmer, just trying to equal things out.
it seemed to work as I had over fifty thousand on that engine, after I rebuilt it at about five thousand, due to bearing failure from condensation creating rusted bearings. Also, that bike had gone through a flood but was supposedly all dried out, by the previous owner, through a mechanic that was very familiar with wrenching on Harleys, a Man that I would trust with working on Mine and, that does1nt happen ofeten, to trust someone elses workmanship On one of My Harleys.:hat:
recian
new bern
curtis
c10 cheyenne
I'm gona give these a shot and see what happens. I'd like to do a MSD upgrade eventually. A modern computer ignition system is sensitive to plug type but I wouldn't think something like what's in this truck would be sensitive to platinums.
Jims86
Patterson,Ca
K10 Suburban Silverado
5.7 TBI
Do Not use platinum plugs with a distributor cap ignition system!
dhamp
Atlanta Area, GA
Derek
R-10 Custom Deluxe
I haven't done it, but why is that? Hadn't heard that before.
I will say this, I just got mine all buttoned back together and stayed up waxing it til after midnight Sat. Sun, I pull it out for a crush, and the thing was running like pure crap. If you get down on it, it feels like you're pulling an RV behind it--making noise, but not much acceleration. If you ease on it, (which is what I was doing) you could actually feel it smooth out and start to surge every so often, then choke back down. Could also feel it on idle--it would be vibrating on idle, then spordically smooth our for a couple secs.
After finishing my errands, I pulled it back in the garage to have some shade and started looking for the arcing. I heard it ticking on the PS, so I looked there. Sure enough, the #8 plug was popping. Figured I must not have gotten the wire snapped on good. Popped the wire off, reattached....same thing. Stared at it a lil longer and realized what I was seeing was an arcing were the porcelain meets the nut. I tried to get a video of it to post here, but it was too small to see on the clip. I'm guessing I got a back plug, so I bought another this morning. Gonna try to change it out sometime this week. That's the only reason I could think of to explain one popping at the base like that.
That being said, for those bursts of good power between arcing, she was good! LOL! I still would only do Delcos. I did the Rapid Fires in my 402 in Chevelle and that SOB ran like it got a fresh rebuild! May do 'em in the square next time.
Motorcraft plugs are the same cost a basic AC Delcos. For a stocker, I'd run the AC Delcos. And BTW, when I say Motorcraft, that does NOT mean Autolite. Don't confuse the 2 as being Ford Products.
MrMarty51
Eastern Montana
Martin
:bowroflwerd6: OOOH, I already knewd that :roflbow:
In engines that have a champion designation, I always use the Autolites, with the smaller electrode, if I can get them in that application. has always worked good for Me. :insane:
recian
new bern
curtis
c10 cheyenne
I got the plugs today. They were labeled as platinums in the computer but they're standard 41-905's with the standard electrode.
anubisani
MIAMI, FLORIDA
SEAN
R/V 3500
454 TBI TH400 4:11 gears
I use NGK in mines no problem so far , I even use it in my bbc in the chevelle no problems here
  • Like
Reactions: WFO
recian
new bern
curtis
c10 cheyenne
I came from imports so I'm familiar with NGK's and used em in everything but didnt know they would work in an older american vehicle.
dhamp
Atlanta Area, GA
Derek
R-10 Custom Deluxe
What setup is in your Chevelle? Old school block? Newer crate?
anubisani
MIAMI, FLORIDA
SEAN
R/V 3500
its a 1988 mark iv the last set of blocks b4 they went to 1pc rear seal
anubisani
MIAMI, FLORIDA
SEAN
R/V 3500
they are very easy to read especially with nitrous, just cross reference them with a/c delco
NateP350
