Spare Tire storage.
87LB
Houston
Rob
So now I have the 33" tires on I am looking for a way to store the spare. I still need to get a 33" on the spare rim, But thought I would as on how those with larger tires are carrying / holding a spare.
I Am thinking of some sort of bed mount. But if I do that I want to get that in before the bed liner goes in..
Any pics?
skysurfer
west coast
1989 Suburban
V2500
5.7/TH400/NP241C
I run 35's and carry a standard size spare. With an open diff in the rear and manual hubs up front the difference in tire diameter doesn't matter.
77 K20
Montana
K20 5" lift
HT383 fuel injected
If you do have some sort of locker and need to have the tire the same diameter there are still a few options. (I'm assuming you are runninga 33x12.50 R15)
To take up less space find a 255/85 R16. Same 33" height, but very skinny. It will take up less room mounted on a wall of the bed, or tucked up under the truck.
Or could get a 33x10.50 R15 which is a little less wide...
87LB
Houston
Rob
Thanks, But I am looking to see how others have stored their spare tire. Ya the tires are 33x1250x15 and the spare will be the same size.
My truck does not have a way to carry the spare under the bed ( someone must have removed it ) so I need to build something. I think a 33" may fit under the bed. But I also think mounting it in the bed may be better. Seeing that I have a long bed the spare would not take up much room..
87R10_Cruising
