Source For NOS Switch?
GregL
Palm Springs, CA.
Greg
K 20
Hi Guys,
I need to replace the HVAC switch for my C60 air conditioning system.
Anyone know a source for this switch that doesn't want $200-$300? Ugh!
I've found used ones priced very reasonable but I really want to go new on this one if I can.
Appreciate any and all input.
Cheers, Greg
:favorites13:
Moderator
You can take those things apart, clean them, apply new grease and they are as good as new.
Moderator
Mine is a '79 so it doesn't have the extra wire, but I think the guts are the same.
GregL
Palm Springs, CA.
Greg
K 20
Hmmm?
Maybe I'll give it try. Mine is leaking vacuum and won't make the proper transfers to the hoses.
RecklessWOT
New Hampshire
Kevin
V10 Suburban Silverado
Well, it was pretty dry. Cleaned it , re-greased it, all back together now. Just waiting for the epoxy to dry and I'll give it a test!
Yeah they're pretty simple mechanisms, not a lot that can make them irreparable unless you completely crushed or melted the thing. Hopefully that's all you need to do for another 30+ years of service lol
16927
Pennsylvania
Bill
C10 Custom Deluxe
4.1 6cylinder
I did the same thing with my reverse light switch on my 1981 C10 three on the tree.... would only work in certain positions of the shifter. Couldn’t find a new one anywhere. Took it apart and cleaned and regressed with die electric grease, been working great.
The Right side of Washington
^ These responses and knowledge are what makes this a great place!
Hadn't considered it and hopefully don't need to for a while (ever), but now I know they can be "rebuilt."
GregL
Palm Springs, CA.
Greg
K 20
No luck. Let the switch set up overnight. Fired up the truck this morning and hooked up the vac plug top the switch before re-installing. Worked it through all positions and nothing moved. Same problem as before. However, if I jumper each position on the plug with a vacuum line from the plug's vacuum source, all positions move as they're supposed to. There is something wrong with this switch.
GregL
Palm Springs, CA.
Greg
K 20
Ugh!
I'm getting something wrong here and having trouble deciding what the real problem is. I used this vacuum schematic for 1977 K20 with C60 HVAC.
It clearly shows the vac connector port numbers:
1-Gray
2-Tan
3-Blue
4-Orange
5-Black
But when I look at my factory vac plug with all the hoses still in their factory spots and then check the corresponding numbers molded on the switch I have:
3-Blue
4-Black
5-Orange
6-Tan
9-Gray
Anybody happen to have one of these apart right now? What the heck am I missing? My truck HVAC system looks completely stock but does not match up at all with the schematic.
Cheers, Greg
Moderator
The illustration on that schematic looks like 80's with the rotational type vacuum switch.
When you had yours apart, did you take out the little slidey vacuum plate doohickey?
GregL
Palm Springs, CA.
Greg
K 20
Yes I did. Took a pic, made sure it went back in the same way.
I agree, the vac connector in this schematic looks like it's for a different truck.
Craig 85
Nashville, TN
454/TH-400/NP205
This guy sells re-conditioned ones. FYI part # 362590 was superseded by #470333. The second link is for his ebay listing. Says it's the last one.
http://thepartguy.com/ac-controls-chevytruck.htm#76-77ac
https://www.ebay.com/itm/401693655835?hash=item5d86cec31b:g:N-QAAOSw1phdGqM5
A/C Heater Master Switch
(GM # 362590/362591)
Reconditioned
$125 RECONDITIONED
Classic Industries says they have one coming soon, but I wouldn't hold my breath. I've been waiting a year for a tailgate band.
https://www.classicindustries.com/product/470333.html
New $129.99
GregL
Palm Springs, CA.
Greg
K 20
Thanks Craig.
I bit the bullet and bought the NOS switch on eBay for $175.
mtbadbob
Montana
Bob
V20
My '87 doesn't blow throught the defroster, so I gotta figure that out also. I did swap the heater control, but to no avail. It looks like all hoses & wires are there & correct, just won't blow air to the windshield.
Johns C10 Hubcap
