Sound deadener "prep"
Ken B
indiana
ken
I am looking to put sound deadener mat down on the floor of my cab. I plan on cleaning up the footwell areas and painting with POR, question is can you apply the sound deadener to POR?
I assume it would adhear the same as any painted surface,,,,,anyone done this before ?
Yep, you sure can. However, POR-15 needs more than just a clean surface for it to adhere. Ideally, you apply it to a surface that has had a quick once-over with a 36 Grit grinder. If you get a surface that the POR will bond to, then you can stick the sound deadening to it with no worries.
Ken B
indiana
ken
right right, i have used it, and will rough it up. was just not sure if i could adhere the sound mat to it. figured it was fine. just lookin for experienced answers .....thanks
rpcraft
Robert
LS 6.0 364 CID
Why POR? Is Rustoleum too inexpensive for you?
87R10_Cruising
