Sooo who has used the upgraded clutch rod?
Burkee1483
When did we get ice cream!?
bealeton virginia
mike
Because I bought the setup from USA1 and let’s just say it’s not at all bolt in lol
Currently bending it to clear my ignition switch/plug in the column.
In theory it sounded great..except the OEM one is offset and bent for a reason.
The ends of my OEM were so worn away I could prob snap off the end.
So some cutting welding etc is in front of me.
I’ll post some install pics next week once I get it all squared away.
I don't think it needs bending. I wouldn't recommend bending it. First thing I'd try is shimming the ends 1 or both left to right,to try to make it line up. I'm assuming it's hollow tube it will collapse on itself if you bend it. Not necessarily now but it will eventually fold over. A little trick on making hollow tube less likely to bend and collapse is drive a solid rod down the center. I'm still of the opinion it can be done without bending it.
Burkee1483
bealeton virginia
mike
It 100% blocks the ability to plug in the harness to the ignition switch on the column. The fact they sell a straight rod with no bend in it to clear things is retarded lol.
If it brakes it brakes. I’ll start over. But the bend is already been done lol
Burkee1483
bealeton virginia
mike
It won’t be in long enough to fold onto it self. I used a press with a round dolly to massage it so it was kicked over just a bit.
With in the next year there will be a hydraulic swap and 5 speed in the truck
It’s a means to an end for the time being
Burkee1483
bealeton virginia
mike
But the entire point of the post is….
It’s marketed as being a direct swap.
When it isn’t.
Just looking out so no one else waste $135 lol
SquareRoot
Lol
First, what year? On my 85 with hydraulic clutch, I cut the end off and tack welded a 3/8 female rod end. A 7/16, grade 8 bolt in the pedal replaced the worn "stub". No more slop or worn out plastic bushings. Will outlive the truck.
Burkee1483
bealeton virginia
mike
SquareRoot
When it isn’t.
Lol
Is it ever?
Burkee1483
bealeton virginia
mike
Lol
74 3 speed
nixon22
