Somebody check my work please...
R8rPhan
California
Mark
1973 (1979?)
C10 long bed (Frankenstein truck)
Doing a complete rewire of my supposedly 73 (but probably 79 cab), most of the way done, just nailing down 2 or 3 circuits that I didn't have a road map for.. until now...
I have scoured over everything I can find on the web to find the drawings I need, and as best I can figure out, the wiring in my truck matches that of the 77-80 (79) wiring...
So, I went through and figured out where all the wires went for my wiper/washer system in the harness that came with the truck..
Since the EZ Wire kit does not come with anything except power to the wiper system, I cut off the old connectors, cleaned/deoxidized them, and made up a schematic to use as a wiring map to get them all hooked up again...
So, please check over the wiring diagram I made and attached below, to see if I have it all figured out right...
Also, since I busted off one of the two tabs on the washer pump when I was trying to disconnect it, and the exact replacement washer pump might be expensive, from what I am seeing, that connector only supplies power and then a ground through the push button switch at the dash..
This being the case, I should be able to get any generic 12v Washer Pump Kit and use it, connected to the same two wires, right (pink 94 and white 93)?
Thanks,
Mark
attachment.php
74 Shortbed
Yep, he'd be the one.
acesolis
