Snow day Weird spark knock on my 84 k30
30backs
Middle Ga
Scott
So we got some snow the other day and I couldn't wait to fire up the old truck and go play it as we never get snow. When I got out on the road my truck seemed kind of underpowered and had a spark knock that get worst when it's under load. I checked the distributor and my fuel filter and they seem to be good any idea?
chevyk10
WV
Daniel
1984 chevy
k-10
358 Dart block with aluminum heads 430hp/450ft-lb torque
So you checked the timing at full advance. What is it set at? Is the gas old? What size engine and any mods?
30backs
Middle Ga
Scott
We'll had to set timing by ear because there is know tab on my timing cover. I moved it to several different locations with same result of spark knock. The gas should be finei Irgun the truck a couple times a month and put gas in it every time. As far as motor it is a 350 with headers and an rv cam nothing special. I hope this helps.
chevyk10
WV
Daniel
1984 chevy
k-10
Generally a knock like you describe is related to timing, low octane fuel or even a lifter maybe. Just no way to set timing by ear. Could be a broken spring in the distributor.
30backs
Middle Ga
Scott
We have set like that for two years no problems until it snowed and got real cold. I took distributor apart and only thing I saw was the diaphragm in the vacuum advance appeared to be bad so I changed it.
chevyk10
WV
Daniel
1984 chevy
k-10
So the centrifugal advance was intact?
30backs
Middle Ga
Scott
yes weights and all seem to be in great shape
chevyk10
WV
Daniel
1984 chevy
k-10
Hmmmm. Beats me one of those play with it and see
30backs
Middle Ga
Scott
man I guess that is the plan right now....loli was hoping someone might have a beter idea than me
Todd Lemon
