Sm465 ticking noise
Ben Roberts
Weston ID
Ben
K1500
I'm new to the this forum and figured I would give it a shot.
My truck started to make this noise that I just could not stand. It makes a clatter/ ticking noise while the engine is under load. I replaced the throw out bearing and it didnt change a thing. It also makes a knocking noise at idle.
If anyone knows what is wrong with it I would greatly appreciate your help.
Charlie
Euless, Texas
Don
Cheyenne 10 LWB
350/TH350/AC/4 BBL Quadrajet
:welcome:
Ben Roberts
Weston ID
Ben
K1500
Yes the oil is full and looks fine.
Here is a video of the noise.
Customblue
Locust Grove, Va
Brandon
Try holding the tension on the shifter and see if noise stops, I had to rebuild the top of my tranny because the forks were worn out causing it to clatter
Ben Roberts
Weston ID
Ben
K1500
Just tried what you suggested and it still makes the same noise.
Customblue
Locust Grove, Va
Brandon
Did you ever find out what the issue was?
Ben Roberts
Weston ID
Ben
K1500
Yes it was some bad spark knock. Retarded it a bit and it was quiet.
wilson79
