Sm465 question
Linville33
Clinton, IA
Justin
K20 Scotsdale
SBC 400
What years SM465 can I swap right into my truck? 83 K20 small block 400 unknown year. I would need the clutch pedal assembly and linkage/master cylinder. There are two on CL right now one says Hydraulic bellhousing for 88-98 IFS trucks (Didn't they switch to driver side drop in 88?) and the other is unknown bellhousing assuming passenger.
Sent from my SCH-R530U using Tapatalk
What trans and t-case do you have now?
Linville33
Clinton, IA
Justin
K20 Scotsdale
SBC 400
700r4 and 208. I don't mind it just like to drive a stick more
MikeB
I have the clutch linkage from an 82 C10. Send me a PM if you're interested.
Sm465/np208 combo would be the easiest swap. Overall length is the same and you can reuse your drive shafts.
Linville33
Clinton, IA
Justin
K20 Scotsdale
SBC 400
Is that setup for hydraulic or linkage?
Linville33
Clinton, IA
Justin
K20 Scotsdale
SBC 400
Mechanical linkage. I'm not sure when GM went to hydraulic.
Do you have the linkage yet or no?
Linville33
Clinton, IA
Justin
K20 Scotsdale
SBC 400
Well my 700r4 took a **** today so now I'm kinda stuck. I can get a sm465 with 205 for 250 bucks on Craig's list. What conversion u join will I need? Also do I need to Change tranny humps or can I modify my automatic on to work with the stick?
MadOgre
NA
NA
NA
NA
NA
You need the shifters for the 205 too! The 208 from the 700r4 will not swap unless you change input gears. And the 208 shift linkage will not operate the 205. As for the hump the 4wd and manual or manual/4wd are the same just that the openings are in different spots. Only the 2wd automatic humps are different.
Don5
West Virginia
Don
k15
If you have a 400 don't forget to buy a 400 standard flywheel. A 350 one will not work since the 400 is externally balanced. I figured that you know this but just in case you didn't.
Linville33
Clinton, IA
Justin
K20 Scotsdale
SBC 400
So I was going to go get a rebuilt trans this last weekend and decided to procrastinate a little longer and a steal came up on my local Facebook. I got an sm465, pedals, transfer case (looks like 205 in the pictures) and driveshafts all for.............. 100 bucks. Best deal I have found :) gonna pick it up in the morning
Don5
West Virginia
Don
k15
Make sure the plate that the pedals bolt too is included. If it not a hydro setup, make sure it has the springs, z bar and the piece that bolts on the frame. That piece holds the Z bar on.
Linville33
Clinton, IA
Justin
K20 Scotsdale
SBC 400
Forgot to update everyone on it. It's a 465 with a np208. And everything to swap. I'm doing it this weekend. Got a flywheel for the 400 and an 11 in clutch kit. Flywheel called for it. Two questions. Since it's a 208 my rear driveshaft is heavier any benefit or running the lighter one? Also this is my first clutch on a chevy. When I did my Honda I ordered a pilot bearing I had forgotten to this time but the kit came with what looks like a bearing and a bushing. If anyone could chime in and help me out and if it's a pilot bearing and a pilot bushing. If that's what it is what would you recommend running? It's a needle bearing type.
Sent from my SM-G920R4 using Tapatalk
82SquareBurb
