Skip White Distributors
MikeB
Those $69 distributors are cheap for a reason. Of course you can always buy a spare, like many Skip W. proponents say they do. Heck even a stock GM HEI will last for 20 years or more with, of course, a new cap and rotor once in a while..
78C10BigTen
pennsylvannia
C10 BIG TEN
So this raises a queston for me, if im replacing a regular hei distributor with an hei 65k supercoil distributor do i need anything special?
82sbshortbed
Why like that?
SE Texas
Doug
1500 shortbed, 1500 longbed
No you don't. Should be that it has a stronger coil and produce a bigger spark. If I'm wrong someone will let us know but, when I bought mine I just dropped it in place of the old one.
legopnuematic
Licensed Junk Dealer
MO
Spencer
I would check to make sure the power wire to the coil is in good shape and supplying the proper voltage to the dizzy.
78C10BigTen
pennsylvannia
C10 BIG TEN
Good point.... my luck itll short out and burn er to the ground.
Tmich396
Long Island NY
Tony
Blazer
Probably will need to widen the gap on the spark plug, check with the seller or manufacturer.
MikeB
Be wary of vendors hyping coil voltage. Heck you can generate thousands of volts just sliding across a nylon seat cover! But how well will that fire your spark plugs at 160 PSI?
Effectively firing the mixture in a combustion chamber is more a function of energy-- amount and duration of current. And I'd be willing to bet none of the cheap distributors with high voltage coils works anywhere near as well as, let's say, those from MSD and Crane.
UNCLECHAD2021
