Size of lift kit
kenn
detroit
ken
c10, k10
Bought 78 k10 with 35 and a lift kit not sure how much lift frame to axle measures 12 inches has stock steering arm, brake lines and sway bar all stock
donnieray
Talks to dogs and trucks.
Roanoke Rapids NC
Donnie
86 C10, 84 K10 MM7 NP833 option truck, 85 K10.
350,355;350.
The springs look stock but appear to have a block between the axle and spring, maybe a zero rate type block? What do the shackles look like?
kenn
detroit
ken
c10, k10
Shackles look stock
kenn
detroit
ken
c10, k10
Do stock springs have 4 leafs? Looks like someone added one or two
nvrenuf
Mobile, Al.
A stock truck measures 8" between the top of the axle tube and the bottom of the frame so I'd say you have 4" of total lift. Definitely not a stock spring because the top leaf appears to have a part number in yellow on it. Imo, it looks like you have 2"-2.5" (depending on company) lift springs with a 1" Zero Rate lift block.
4" springs don't have a lot of arch but it's noticeable whereas 2"-2.5" are basically flat, this is why I don't think they are 4" springs.
donnieray
Roanoke Rapids NC
Donnie
350,355;350.
I agree, and the drag link has an angle that looks to be 4" or so of lift. The flatness of the springs threw me off though. I have 3" lift TC EZR and there is a definite arch. I'll try to get a pic later, raining out there now.
kenn
detroit
ken
c10, k10
Want to raise truck 1 inch or 1 1/2 inch in front , (not 3 inches) trying to decide 4 or 6 inch lift springs truck has 35x12.5x15 on 15x10 rims tire measures 33 1/2 inches on truck
Moderator
I think you are spot on.
kenn
detroit
ken
c10, k10
I have seen the stock measurement as 9 to 10 Iinches you 100% on the 8 inches?
Moderator
The measurements really don't matter too much, those springs are basically flat, like a 2.5 inch lift spring. They aren't stock and they aren't 4 inch, that's for certain. That driverside spring has a number that you could look up.
Moderator
You could do a 4 inch spring and a Zero Rate block to get the extra inch needed. Then those aluminum blocks can be pitched. You will want a raised steering arm too.
nvrenuf
Mobile, Al.
8" was the consensus of a big thread on CK5.
kenn
detroit
ken
c10, k10
Looks like number is 08G13 on spring will check again when daylight
Craig 85
Nashville, TN
454/TH-400/NP205
Hopefully this will help a little. I installed new front 4" lift springs on my last truck and a 4" block in back. It had the factory 6 leaf set up in the rear. The upper trim horizontal body line measured 32" from the center line of the axles.
dan86
