Should I replace the receiver drier?
da_raabi
Trailer Park Supervisor
FloriDUH
Adam
c30
So I started rebuilding my A/C about 3 years ago, but when I went to have a new compressor installed it ended up being seized. I never got back around to finishing the job. At the time I installed a new receiver drier and expansion valve thingie (the little plastic screen/stick that goes in the line) along with all new o-rings.
I'd like to go ahead and finish the job, should I replace the drier (or anything else) again? I taped/zip tied plastic bags over the open lines (where they would connect to the compressor) to keep junk out.
Is the drier still good or should it be replaced again? I don't want to over-spend on the job, but then again I don't want to have to go through this again.
Thanks!
yevgenievich
Place
Name
Year
Model
Size
Replace the drier. Unless it was maintained under vacuum or gas pressure it is likely saturated. I have stored a good dryer before filling with a bit of gas and capping
Colin
Covington, GA
Colin
K10 Silverado
350 cu. in.
Many compressor warranty's require a new dryer/accumulator & orifice tube each time in order to be valid.
They're pretty cheap... less than $20.
Snoots
Roger
Jimmy Sierra
350 w/203
Replace the drier.
