Seat swap to rears from a 2014-2018 Silverado...
83Stepper
Massachusetts
Chad
Found an amazing deal on a 60/40 split rear bench out of a 2017 Silverado in the right color for $40, next to nothing, near me. Hard to say no when it's for less than filling up my 16 gallon tank lol. Currently have some buckets that the PO fab'd into the truck using some earlier 70's seat brackets and some heavy modification to them. Purchased a bench out of a 85 C30 that has some tears in the vinyl for $40, mainly for a temp bench until I could get something better. The cost to cover the current bench is more than I want to spend on this daily for now.
So I'll be documenting the process and figuring things out as I go along. Yeah there are others out there that have done it before, but I want to do this with a much more simplistic approach that just about anybody can do for next to nothing. Yeah the new split bench needs to be cleaned up, but that's part of the fun!
EvilGenius
Metro Detroit
Darien
As someone who has ridden on the factory bench seat and those same back seats in my daily, I think you'll be happier with the oem bench seat. Those back seats are cheap. Not much pad to them and they are thin.
I'm curious how you will end up liking them when you are done.
Edelbrock
Earth
Grumba
K5 Blazer
I have spend a fair amount of time in the back seat of my rig too, but to be honest - the comfort of the bench seat has always been the last thing on my mind. Never heard any complaints about it from the ladies either.
Scott91370
Burleson, Tx
Scott
Sierra1500
I look forward to this write up. Been eying them myself but after my first go around with a set of 2005-ish Ram 40/20/40 seats (and not having enough room to get away from the steering wheel) I've been a little gun shy trying another swap.
83Stepper
Massachusetts
Chad
Really just looking for something that'll get me by cheaply where my wife and teenager can come along for the ride and not get slid into each other during turns lol. Plus the PO moved the shifter from the column to the floor, so not sure how that'll interfere with the geometry of the original bench.
Same, I'm 6'4" and 240 and being a taller guy these trucks aren't the most roomy. Not planning on making a lot of modifications to it and I've always got the oem bench just in case.
83Stepper
Massachusetts
Chad
So I did a few things this weekend to get ready for the seats to go into the 83. Had to at least clean them up a bit with an upholstery cleaner. Still in the very early stages of mocking it up and getting them tossed into the truck.
1. Need to remove the covers on both sides, the outermost piece clips in and has a few slide locks that hold them into place. The inner most cover has a slide and a few torx holding it into place.
2. Next you'll need to remove the spring for the seat brackets. No real easy way to do it, I just pryed the everloving sh-t out of it until I was able to distort the inner most coil enough to slide it out of the pin.
3. Once that spring has been removed I drilled out the edges of the backside on the pin. That was the easier way that I found to do it. Did it on the passengers side differently, thus learning it's easier to shave off the flats than trying to drill it out. Might've been easier if I had a step bit, but working with limited tools here.
Pin is shaped just as seen here, bit of an oblong rectangular shape. Once you've got the ends of it cleaned up, you just have to knock it clean outta there.
Once those were out, I was able to remove the outer most seat brackets that I won't be using from both sides. Ended up removing the seat covers for the lower cushions to expose the seat foam and frame. Just tossed them into the truck to see how they'd feel with the current setup used for the Fiat X1 9 seats installed by the PO. They feel like they're at a good height and they actually feel more comfortable than the buckets now.
Slapped the buckets back in for now until I can get the square tube stock that I'll need to mock up the frame using a set of original bench seat brackets. Think I might end up using a set of mid 70's that have the slide on the door side instead of the one between the legs in the front of the seat just to make things fit easier. Will keep the post up to date as I go along with it.
evlz
ca
ernest
6.0l lq4
Looking good
85_k10
