Seat belt bolt removal tips?
wczimmerman
Bothell, WA
William
V2500
5.7L
I need to replace two of the seat belts in the back seat (no shoulder belts in the 87) but I cannot figure out how to get that bolt out. I bought an electric impact wrench and impact T50 socket but that bolt is just stuck in there. Any tips? Should I move to pneumatic tools instead for more power?
yevgenievich
Place
Name
Year
Model
Size
Breaker bar with a lot of penetration fluid. But even that did not work for two bolts on my suburban and I had to resort to drill/tap/weld method
1987 GMC Jimmy
Automobile Hoarder
Mississippi
Jesse
V1500 Jimmy
Same. On my brother's we used a piece of steel tubing as a breaker bar and a rather plumpy ratchet.
donnieray
Talks to dogs and trucks.
Roanoke Rapids NC
Donnie
86 C10, 84 K10 MM7 NP833 option truck, 85 K10.
350,355;350.
I was able to get mine loose with a 24v Kobalt 1/2" impact. My 84 K has the bolts with hex heads though.
Georgeb
Wisconsin
George
K10 Burb Z71
Whenever I could get to the other side of the bolt I would wire brush the rust off of the exposed threads and then spray it with penatrant. Then work the bolt back and forth with my impact while adding more penatrant from the top. Rarely did I need heat but heat always helps.
CRM
Pasco, Washington
Casey
K2500
350 CI
This is old school but take a log lighter and hold it on the bolt head as long as you can, then use your wrench (with breaker bar if necessary) and it should let go.
bajadiver
