squaredeal91
- Mar 10, 2023
- Cave junction Oregon
- Greg bush
- 1991 SB
- K30
- 5.9 Cummins 12 valve
How I find TDC compression is I remove #1 spark plug, stuff a rag in the hole tightly as to make a seal. I even pack it with a screwdriver or something without getting the rag inside too much inside combustion chamber. I bump it over with the starter until I hear the rag pop out, it should be audible if done right. Then move balancer to line up with timing mark.
Sometimes it's difficult to re-stab distributor and get rotor lined up. You can use a large slotted screwdriver if it's long enough to turn oil pump so distributor stabs where you want.
