SBC STUFF
custodian
Catawba
William
C10, C30
5.3 LS, 350, 454
I'm cleaning out my building of all my older SBC stuff. I have 2 quadrajets, one I know is good to go the other I'm not sure, a 1964 283 bare block with main caps that's never been bored, a 307 block with crank, pistons and rods (disassembled), a rebuilt points distributor (almost new), Used 350 2 piece rear seal crank (most likely needs turned}, 307 2 barrel intake, 350 non egr quadrajet intake, used oil pans, 283 valve covers, 350 GM crate engine vale covers pulled to install chrome ones (NEW), a new set of center bolt 350 valve covers, a set of Oldsmobile MOROSO gold anodized that have been painted Olds blue (NEW never used), and whatever else I find. I'll post some pics later. Make me an offer and come and get it.
UPDATE: 2 flywheels (one is for an 11" clutch, the other for a 10.5 clutch, cast iron bell housing from a 67 C10, 5 bolt aluminum bell housing from a 73 C10, used Comp Cam 268 duration, 454 lift cam, box of used valve springs and valves. I also have a set of 327/250 heads with Wolverine valve springs, TRW valves and valve locks with about 30K miles on them, bare 350 heads, 283 heads (will need reworked), also have 350 heads with valves and springs.
Also have some 87-93 Mazda B2200 truck parts.
Have any idea what models the two Quadrajets are?
custodian
Catawba
William
C10, C30
5.3 LS, 350, 454
custodian
Catawba
William
C10, C30
5.3 LS, 350, 454
1972 C10 704221 and 1973 C10 17054919
custodian
Catawba
William
C10, C30
5.3 LS, 350, 454
SOLD.
crpntr78
Missouri
Can you get some pics of the intake? Thanks. Shipping an option?
crpntr78
Missouri
Sorry, the 350. Thank you.
custodian
Catawba
William
C10, C30
5.3 LS, 350, 454
I think shipping would be a killer on a cast iron intake.
crpntr78
Missouri
Probably so, thanks anyway.
crpntr78
Missouri
No, but thanks anyway.
78C10BigTen
pennsylvannia
C10 BIG TEN
I learned from uncle tonys garage on youtube that the usps flat rate boxs are your friend! As long as its in the box they dont care if its sides are bulged out. As long as its under the weight limit.
custodian
Catawba
William
C10, C30
5.3 LS, 350, 454
EVERYTHING IS SOLD.
Octane
Atlanta
Eddie
Do these For Sale threads ever go away after the items are sold?
Stickman
