SBC motor mounts not lineing up
Chuckyj95
NY
Chuck
We took a 350 SBC out of a 84 k10 and we are putting it in a 1986 C10 frame but the holes on the engine brace aren't even close to the mounts I took of the K10. This is not my wheel house and I am helping my son build this. Can I use the engine braces from the K10 or do I need to find different C10 engine braces.
xm20k
Girard, Ohio
No idea what those frame perches are but they are not correct.
This is what the C10 perches should look like.
Chuckyj95
NY
Chuck
So I guess my next question is can I use the ones off of the k10 doner truck.
idahovette
Firefighter
Weiser Idaho
Perry
K20-K10
I don't know for sure but I'd give it a try. Look at what @xm20k posted, are they similar?
xm20k
Girard, Ohio
Moderator
I'm guessing the C10 was a 6 cyl rig?
Sad Sack
Nebraska
Goober
C15
Strick
Dunn, NC
Harold
C20 Crew
If the 86 had a 4.3 then you'll need to change the stand & they are different on K trucks. The mounts are the same on SBC & BBC.
HS
Chuckyj95
NY
Chuck
Motor went in like a glove. Drilled new holes on the motor stands and 3 out of 4 holes on the transmission cross member lined up. Next step put a cab on
Shifted
