C10 engine advise need
Aj Farias
Adilson
Silverado 1500
What should i do on my 84 c10?
I dont want to do ls swap, i allways want to leeve a matching numbers engine/trans for a future sell, but im changing my mind and built for my self and if want to sell one day its what its.
Now she does have 305 and to rebuilt i will spend a good money, so im thinking to buy a 350 or 383 stroker sbc (more inclined to 383) around 400's hp and drop on her.
What do you guys recomend to do. Whitch way do you guys think keep and rebuilt my 305 or buy one of this 2 engines and which one of the 2?
Your choice of engine depends on what you are going to use the truck for. Buying Ice Cream on Sunday? Daily use as a truck? Towing? And how much you want to spend on all the other things to make the new engine selection work as intended.
Aj Farias
Adilson
Silverado 1500
Will be use just for around town weekends basically, no haulling or pull anything.
I have seened complited 383's for around 2.5/3k.
Aj Farias
Adilson
Silverado 1500
Seeing*
Yep and with a 400hp 383,you probably will want a different torque converter yours probably stalls too low, and a transmission upgrade in the near future because yours probably isn't going to last long, also rear gears, headers,bigger radiator,and better exhaust.
CalSgt
CA
Casey
Chevy K-10 Custom Deluxe
350 or 383 are both good options, It's likely anything will be an improvement over a 40 year old 305...
You'll probably have a noticeable gain just dropping in a 2 bolt main Goodwrench 350, they're rated for like 240 Hp IIRC. You could squeeze a few more Hp with a small street able camshaft.
I'd bet the old 305 was rated for less than 200 Hp.
xm20k
Girard, Ohio
A 350 or 383 at 400HP you're going to need a torque converter, and a trans shop to rebuild and upgrade the trans (most people won't do their own). As well as all the other things that need upgraded to handle the extra heat and power. You're not just going to drop a $3-4k long block in and be done your looking at twice that if not more.
A 275-300HP Small block you might get away with that depending on trans.
This is from the guy that drives a 550~600HP drag truck on the street, most people aim too big then don't like how ill-mannered their vehicle is and or lose interest due to cost, usually before it's back on the road.
75gmck25
Northern Virginia
Bruce
Start out by determining your approximate budget, then looking at what choices you have for that price.
Then pick a cam and heads based on your planned use, rear end gears and transmission. For example, for a DD you probably want a balance between increased power and keeping good gas mileage, but for a weekend-only fun truck you can get more extreme and not worry about gas mileage and around town driveability.
Confused
Angier NC
George
It all depends on what you want the truck to do and how much you want to spend to get there AND upgrade everything else to support it.
A simple 350 with dual exhaust, a small cam,and a better than stock set of heads will make. driving a lot more enjoyable without hurting resell either. A recurved distributor and 4 barrel carb will make a well rounded engine that performs well. Don't even need headers at this point but will slightly help power if you do.
Hotrod trucks are cool but can become money pits and have a narrower pool of prospective buyers.
Aj Farias
Adilson
Silverado 1500
I think my 305 its around 190hp
awar
K35
Do you have the original 4 speed automatic? Does it work properly? Is your engine needing repairs or is it just under powered? Is your exhaust stock? Are you looking for better sound? Maybe a quality exhaust upgrade is all you need.
160hp 235 torque a very mild 350 would get you another 100hp and 100 ft lbs and not have the extra expenses of trying to make a 400hp engine work in your truck. Actually you are going to gain more than that if your engine 8s worn out.
Aj Farias
Adilson
Silverado 1500
My friend told me just to drop a 350, alum headers, exaust man, a small blower on top and rebuilt my TH350.
He think i will b spanding a lot less money and use my rear end and trans without problem and still fun to drive.
The Right side of Washington
Subtract 40-50hp from that and you’d be right, assuming it runs prefect “like new” so to speak.
Assuming it has a 700R4, I think all 305s got that and the turbo 350 was an option with ….idk don’t remember.
Personally, it depends on your budget and whether you like to do big burnouts!
Keeping it “matching numbers” is of little to no value, short of an original time capsule type truck. And even though yours looks to be in very good condition, guessing it isn’t a real deal time capsule.
Plus you want to enjoy it and unless you’re not into cars and trucks (which you likely are if you’re rocking a 40+ year old pickup with pride!
It’s gonna be expensive anyway and a bunch of work and the 305s are unique in that they have some real cobbled up 80s emissions features that weren’t on the bigger engines. Makes them more of a challenge to get running “perfectly” if staying nine stock and reusing major components like carb and ignition.
Given all that, I’d go for simpler and at least double the power you have now.
700R4 will need a real rebuild and TC to handle it, but it may be old anyway(??).
You’re planning on keeping the truck so do what you want to do (within reason or budget), imo.
doo-daa
