S10 driveshaft replacement question
78C10BigTen
pennsylvannia
Ted
C10 BIG TEN
So a question to all you s10 owners out there... my 91 has a 2 driveshaft setup with a carrier bearing in the center and carrier is toast. My question is can i dump the whole setup and put 1 solid DS in instead? Is there a solid DS for a regular cab, long bed s10? Thanks
DoubleDingo
Right where I am
Bagoomba
Carb'ed Vortec 350
Not an S10 owner, but I would just replace it all with new and be done with it.
78C10BigTen
pennsylvannia
Ted
C10 BIG TEN
The whole setup with both drive shafts and carrier brand new is almost $1k!!!!
78C10BigTen
pennsylvannia
Ted
C10 BIG TEN
Carrier is only like $6 but i really hate extra moving parts and places to break. Rather have a solid DS.
idahovette
Weiser Idaho
Perry
K20-K10
@78C10BigTen , Ted I have a complete 2 piece driveline laying out here on a spare long bed frame, right beside my spare regular cab and front clip. Filler up and come and get'em
idahovette
Weiser Idaho
Perry
K20-K10
Can you get the measurements on it from center u-joint to center u-joint and post?..About where it all rides when hooked up
78C10BigTen
pennsylvannia
Ted
C10 BIG TEN
Wich shaft? Front u joint to center? Center u joint to rear??
idahovette
Weiser Idaho
Perry
K20-K10
I'm looking for the total length of the shafts combined. I have a very straight cab and front clip, originally white, but painted silver now. We have been using some pieces of the cab for Kooper's truck but putting all the old parts back in it to save for the next guy. We are using the frame to mock up the SBC we are gonna put in Kooper's s10. I'd make you a heckuva deal on the whole thing,...can you say "Road Trip"??!!!.....for the shaft, @Buckets Chevelle wagon may have a long enough shaft??...Maybe?
DoubleDingo
Right where I am
Bagoomba
Carb'ed Vortec 350
No way three u-joints and a center bearing are going to cost 1k. Did I miss something?
78C10BigTen
pennsylvannia
Ted
C10 BIG TEN
Ok so now im confused because it showed this same part for 2wd for like $900! Now i go back and theres only a few part choices and the only one that looks like mine is listed as 4wd?! This one. Also listed as ext cab short box. Wtf
DoubleDingo
Right where I am
Bagoomba
Carb'ed Vortec 350
Wow that is pricey! Are u-joints and center bearing considered non-replaceable on those?
78C10BigTen
pennsylvannia
Ted
C10 BIG TEN
I can honestly say that the u joints are factory because they still have the (poly ?) Sealer thing in the cups that you hafta melt out to pound the cups out to replace with new u joints. Its all still attatched but the big rubber in the carrier it floppin up n down as i drive causin one FOOK of a noise and vibration! Hence why id rather a 1 pice shaft!
DoubleDingo
Right where I am
Bagoomba
Carb'ed Vortec 350
I get it, but those engineers knew something we don't. I forget the cutoff point before a driveshaft is too long. It's not like you have to replace this stuff yearly.
Hard
