rusty floor, rocker panel, kick panel repair V10 1987
JAngeli
Lisle, Ont. Canada
Joe
Keep up the good work, I'll be in the same boat next spring with two trucks. Keep sending pics. :cheers:
TheFishBox
OR
nick
v30
6.0 ls
That's looking good. Thanks for posting pics, I am getting ready to sand blast my cab and I am not looking forward to doing the rust repair.
74 Shortbed
Nice work..
OkieFishMan
Certified Camping and Fishing Nut
Enid, OK
OkieFishMan
GMC C2500
454/SM465
Good pics and good work!!
DanMcG
Central NY
k10 k10
Very nice work, thanks for posting it
Moderator Administrator
Alot more patience and skills than I have. Great work there. :waytogo:
74 Shortbed
Wish I had the skills to do that stuff..
I see guys doing this work and it just makes me sick I scrapped that burnt truck cab. The firewall was rusty and all the wiring was melted behind the dash, but the floors, rockers and door jambs were pristine. Someone could have cut out some damn good OEM sheet metal to weld into their cab. This is why I hate scrapping any of these trucks. Same with that Burb. NO RUST anywhere.
roadwolf
France
Rodolphe
silverado 10
Before trying, i didn't know do this.
The first thing needed is good mig welder.
Several years ago i tried to make some weld repair on my jeep CJ7, and it was a disaster, i though i was unable to weld something correctly, but when i started this a job, a friend of mine who know how to do came with is own mig welder, and when i tried to work with it, i managed to weld without making holes.
You don't see the miss, sometimes it s not good at the first time i have to cut an re-weld, i am very bad at taking mesurement, the parts do not fit well, they are bigger than the original (like an overlay).
This kind of job takes a lot of time, if you are not used to do this, but there is nothing undoable.
Saturday i wanted to finish to put the rocker panel.
as you sse the bottom of tha A pilar doesn't fit well, with cutting and hammering it will go at is location
also the edge didn't have the same shape as the parts on the cab, so a cut wheel attack and some spot weld had solve the problem
everything fits now correctly or as good as i want
I had to stop, because of thr rains, wind and the night falling, i didn't see enought under the cab to do a good job
to be continued...
74 Shortbed
Coming along great..
Iowan
Loud and Proud American!
Iowa
Calvin
K1500
350 crate
Looking Great! I have to do this over this winter so this is a lot of help for me! How are the supports going from the cab mounts?
roadwolf
France
Rodolphe
silverado 10
The rust was only in the rocker panel, probably because of a hole in the inner fenders which let mud and moisture stay in this area.
A bad car seller made cosmetic repair of the cab corner which was made of polyurethane foarm and bondo, now it is still again.
the arch wheel of my bed are also rusted, i'll do this after the cab.
Iowan
Iowa
Calvin
K1500
350 crate
Same with my truck, everyone says flat bead it, but then I loose the versatility. Stupid question, what is an inner rocker?
dan86
