rust converter under heat paint?
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
More specific, high temp header paint...
I have a set of dandy Hooker headers that are rusty and I'm not in position to sandblast so I've been manually having a party with the side grinder and brush. Of course I'll never get the rust in between the pipes. Well I'll run a strip of emery between the pipes anyway to knock off the worst.
Is there any reason why rust convertor can;t be used? As far as I understand, it leaves the rust as oxide and that shouldn't have any effect one way or the other under the heat paint.
What's the gang's comments on this?
Frankenchevy
Proverbs 16:18
Square
CUCV
Small
Maybe phosphoric acid overnight followed by a soapy water scrub with a 3m pad. It neutralizes the rust, but the residue can be scrubbed off.
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
That's probably a good idea anyway, and I have some too.
I was once told by a circle track racer that there's a trick to keeping headers from rusting out. Every year or so, remove the headers and get them good and hot with a rosebud torch, then douse them in ATF while they are still cooking hot.
I've never tried it yet. One day I will, lol.
gotyourgoat
NRV Virginia
gotyourgoat
smokin' 305
I'll bet it is another way to preserve them. Kind of like seasoning a cast iron pan. It's best to have long even heat for an even seasoning though.
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
Sounds messy... and fun.
FenderBanger
