running th400 without kickdown...bad?
Oregon78k10
Albany
Wes
350 V8
I've recently put a th400 in my truck. But I don't have a kick down yet...is it bad to drive it like that?
Oregon78k10
Albany
Wes
350 V8
So I shouldnt drive it till I put one on
chengny
I run TH400's without kickdown capability more often than not.
Usually because the detent switch on the gas pedal is missing/out of adjustment, the actuating wire is broken or the downshift solenoid is burnt out.
I always get around to fixing it eventually, but it's not a priority.
There is no consequence to running a TH400 with out the downshift detent function - other than you have to manually downshift on steep hills with heavy loads.
If you're thinking it's like running the 700r4 without the TV cable hooked up or adjusted, NO, it's not like that. You will not harm the trans wo it hooked up.
However, I would be paying attention to when you'd need the downshift and do it manually. If you're running in 3rd when you're going slow enough or climbing a bit of an incline then you're putting a strain on the trans and going to heat it up real good. Sometimes, especially in lower geared trucks, the governor alone will NOT kickdown as you'd expect.
MIDWESTCUSTOMS
