Replacement carburetor recommendations
xm20k
Girard, Ohio
Without know what we are working with there's a bunch of cheaper replacement carbs for these but which one.
xm20k
Girard, Ohio
Moderator
Same. And I was corrected that only just a few years earlier, the General actually offered a 1bbl carb on a 250 engine.
Guess I should have known that bit of Squarebody geekology, but like you never really saw any/many. The V8 offerings of the day were poor enough in performance that all the trucks I was around or responsible for had V8s.
But this is just another one of those hypothetical discussions for the rest of us that is getting deeper and going down rabbit holes due to an off hand request by the OP to look into out crystal balls and decipher what carb he has and where to find him a new one….I”d take the air cleaner off and look at the carb personally.
But apparently neither he nor his mechanic are able to.
Crystal ball? Do you mean Magic 8 Ball?
All signs point to "yes". Lol.
Brownie82C10
Winter Haven, Fla.
Joe
Chevy C10
4.1L Inline 6
Thanks, all, for the comments and recommendations. I think my truck had a one-barrel carburetor when I bought it (perhaps the Rochester 1ME?), and I'm fairly certain it was replaced by a like-kind carb. According to my Chilton's repair manual, the E2SE 2-bbl carb was introduced on Chevy pickups in 1983. Here's another thing my mechanic told me: "It's sucking air somewhere, maybe at the carburetor or the manifold." He said he would do some more investigating to find out where. He said the engine would rev up when he sprayed around with carburetor cleaner.
Moderator Administrator
Paying someone else to do a small block swap on a truck that has been good to you as is for 26 years,doesn't sound like the best solution to me. If a person was doing their own work and weren't happy as is,with their 6 cylinder truck heck yea a small block swap would be a great suggestion. But there are a lot of things going to nickle and dime this,if you have to pay someone else. And if you live somewhere with emissions inspections,there's another problem. As for a carbureator for a stone stock 6 put a good reman from a reputable rebuilder like national carbureator on it. There is no since in trying to modify a tired 6 cylinder you'll probably get more problems than solutions
Totally Agree. Only do the sbc swap if you want it done, but otherwise, just keep patching that 6. You'll never kill the internals on that thing. Now, if that 6 does by chance go titz up from like a lack of oil, overheat and crack a head which they are notorious for if it's the integral head, and yes, that'll probably happen but usually where it happens, it doesn't affect anything USUALLY believe it or not. I've pulled several apart with cracked heads in certain spots and it didnt' affect a thing and no leaks, no mayo oil or nothing. But if it goes, THEN YES, I'd do the SBC swap. And reason I say that, it's cheaper to rebuild a 350 or buy a crate 350 than it is to rebuild the 6. No Lie, look up the prices. So then the money saved on the rebuild or crate, that'll help cover your new exhaust and other nickel and dimes.
I had a 64 GMC a long time ago. It came with biggo honkin V6. I had every combo you could think of in that truck, and I never once hit it with a torch or welder, or aftermarket parts as far as crossmembers or mounts etc. EVERYTHING bolted in once I acqured the correct parts. I had I6 in it, several small blocks, 2 big blocks, Granny 4 speed to Muncie M21 to M22 to Th350, Th400. The fantastic part was, swapping from the Muncie 4 speed to the Th350's, I didn't even need to swap the driveshaft. Same driveshaft fit both. I had kits set aside, so like whne the Muncie came out, there went the center hump with the hole cut in it and boot. So then I used the hump with a small hole for the B&M Quicksilver Ratchet shifter cable to go through. Had 2 wiring harnesses that plugged into the firewall, 1 for v8 1 for I6, and with that wiring harness, I kept the correct factory throttle shaft rod from the pedal linkage to the carb. We were crazy back then. We'd borrow each other's engines for the weekend to go run races and try different combos. Sometimes, I'd put the old 230 i6 in to loan my engine to a buddy, or to do a rering and cam swap. We raced our everyday drivers that we drove to work, so if you raced and broke that weekend, you'd better have a back up trans and engine ready to go in or you missed worked Monday. I also had dual exhaust for the I6, so yes, I did have to save 2 sets of exhaust. The small and big block was easy, used the same pipes off the headers for both. I could convert from v8 to i6 in 4 hours and the same going back to v8. You never knew when I showed up at the street races what I'd have in it. All that stayed the same was the Dana 60 with 4.56 and Detroit Locker. I'd be auto trans this weekend, next weekend, back to the M22. I finally broke the M21 and that's when I went with the close ratio M22. Damn, so much fun to drive with about 400 plus horsepower, maybe a bit more, not sure, never dynoed. And that don't sound like much, but were talking in the 80's and it may have been closer to 500hp, no telling. I just know it hauled ass and was hard to keep straight with the locker in the rear end always breaking those 33 inch tires loose. I think my best combo was a SBC with the M22. The big blocks were fun too and won races of course, but for ricky racing around town, breaking tires loose, 2nd and 3 gear chirps etc, the small blocks just seemed more peppy. I'd imaigne a lot of that had to do with the rpm power band and camshaft choice. Of course if you wanted to, you could do the same with a square. Just save all the factory parts you get to make it happen, so you can go back and forth.
Oliver
Joe
In case your poor performance does not improve with a carb change, please be aware that the L6 does not have a timing chain. It has a fiber timing gear that can have a worn or broken tooth causing timing issues. It happened to me once. Worth taking the timing gears cover off to check out.
nbkk43f
charlotte, nc
Nick
No sure if you got this squared away or not yet - but I just picked up a stock 78 C10 with the 250 and a Rochester Monojet carb. The PO had some carb issues and put on a cheap amazon replacement, unfortunately he didn't keep the original monojet. I ditched the aftermarket one, picked up an OE rebuildable core on ebay for 75 bucks, along with a rebuild kit from Mike's Carburetors. Cleaned it all up, rebuilt it, good as new. If it's not a monojet, then some pics of the carb would be great if you have them. Otherwise, sounds like more investigation is needed regarding the vacuum leak.
Nborden88
