Replacement cab
777mech
Stanwood, WA
I need a rust free cab for my 76 c10, anyone know where to look? Can't find one in seattle, lol
You will probably have to go to a different part of the country where it does not rain so much, and they don't salt the roads.
My truck was originally on the farm in North Dakota (lots of snow, but no salt), then in San Antonio (no snow, not much rain) and now in Virginia (quite a bit of rain and humidity; salt on the roads). I have seen more underbody rust develop during the last six years in Virginia than my '75 truck had in the rest of its life. Where the truck is located makes a lot of difference.
1973c10
Don
How far do you want to travel and how much are you wanting to spend
and does it have to be a 76 ??
777mech
Stanwood, WA
It doesn't have to be a 76' as long as everything can be made to look identical to a 76' with minimal effort. I don't want to spend much more than 2k shipped.
1973c10
Don
Look at CL Portland there is a few complete trucks on there
that is what I ended up doing bought a truck for the cab then resold the running gear
https://portland.craigslist.org/clc/cto/d/portland-79-chevy-silveradoruns-drives/6809594324.html
https://portland.craigslist.org/mlt/cto/d/scappoose-1978-chevy-cheyenne-20/6788039699.html
https://portland.craigslist.org/wsc/cto/d/manning-1978-chevy-truck-custom-deluxe/6797790209.html
roundhouse
atlanta ga
justin
77,78,79,80 ?
Aren’t all cabs identical except for the seat belt mounting points on the 76-77?
I know the dash pad is different
Will a 76 dash pad for on a 82 dash frame ?
You’re gonna have to go look at it
Don’t send money for a rust free cab and spend more money to get it shipped
The seller will definitely lie unless you know the seller personally and trust them
There were cab differences through the years. Wiper switch mounting changed slightly in '75 I think, then another slight change in '78. In '79, the VIN moved to the dash. In '81, the cowl changed to accept hood hinges and wiper posts used 3 mounting holes instead of two. The dash also gained speaker holes on each side of the dash, under the pad. In '84, the wiper switch moved to the column, so the headlight switch moved north an inch or so on the dash.
The different trans humps in the floor is a whole nother conversation.
btrain04
