FreeTruck
- Mar 8, 2022
- Texas
- Tim
- c10
I'm trying to find a replacement for the connector that goes through the case to connect the harness from the TCC solenoid and governor pressure switch. My present connector is a turquoise color, with two blades to connect to.
Here's an example of what mine looks like in a different color:
suntransmissions.com
All I can find available online is something with three prongs, like this:
Does anyone know where I can get a proper two prong version? This appears like it would work if I just break off that one unnecessary blade. What do you all think?
Connector Case 2 Prong Oval Type TH700-R4 TH350 TH350C TH125 TH200 TH325 TH250C
Shop at Sun Transmisisons for all of Automatic Transmission Sensor Solenoid Block Connector Wire Harness Solenoid Switch, 12300205 8633549. Free shipping with minimum order.
