- Apr 11, 2017
- kansas
- Rick
- c20
My 75 when I got it came with preneglected hinges and a prebent hood. I took the springs off and straightened the kink. Now I use no springs and a prop rod. The newer style hinge would make it easier,but not as much tension as factory springs,I'd still need a prop rod but lifting it would be easier. Gas struts if they were strong enough to hold the hood up would still be strong enough to bend the already weakened hood. I might try later hinges,probably not,because that would require more effort,than just manhandling the hood like I do now.80s hinges also need gaskets https://newboyzsquarebodyrescue.com/products/hood-hinge-gasket-set-1981-1991
do you mean the ones with the gas struts? i dont know if 81+ hinges can be used on a 73-80 , because the hood and cowl geometry and probably locations on the hood itself
From what i can tell 81+ use a simple hinge with a coil that assists opening that is separate so its less susceptible to the side-to-side wear on the pivots of the old hingesYou must be registered for see images attach
