Refurbishing a grille...with wood
EastAustinSawdust
Austin, TX
Adam
C10 Big Ten Bonanza
5.7L 350
My 78 had an original grille and emblem, and they were in rough shape. So I got a new grille and emblem (LMC). Only problem was that the aftermarket grille wasn’t designed to hold an emblem:
OEM grille:
Aftermarket grille:
Replacement emblem and original emblem:
So I made an adapter using the materials and tools readily available to me. And that happened to be a scrap block of walnut and the woodshop in my carport.
The block was off some scrap from a friend’s cabinet shop. 8-4 walnut. Not too shabby for scrap wood.
Reached the emblem and cut to shape. Not sure how, but this is evidently a comfortable position for my dog to lay in.
The block needed to sit recessed in the grille, which meant cutting out detents for the plastic grates. Also cut holes to attach the emblem via those little thread cutting nuts.
Ahh yes it fits perfect. Oh **** nevermind, the grille is upside down. Had to cut a few more dados in it to fit right side up.
This is why I picked a really hard, dense wood. With some poly I hope that it can withstand the elements without warping/rotting. Worst case scenario I just make a new one.
Fastened with a metal strap that I bent to fit the grate:
There we go. Thought about sanding, finishing, and leaving as-is.
Reattached metal trim with OEM thread cutting bolts, which I soaked in CLR overnight. Reattached grille. Looks good. The bumper guards are new too.
Quarantine looks good on this old Bonanza.
EastAustinSawdust
Austin, TX
Adam
C10 Big Ten Bonanza
5.7L 350
When it comes to flesh wounds, it’s hard to beat WD40’s penetrating action. But for medical reasons I use 3 in 1 oil.
idahovette
Weiser Idaho
Perry
K20-K10
OK, first ,I spray with brake parts cleaner, then wipe, check damage then a blue towel ,then the WD40. Haven't tried the 3 in 1 yet!
That's awesome! So for the price of a cheap grille, a block of wood and some of your time, you've got a grille that would have cost a bundle otherwise. You can't beat that with a stick.
Excellent work. I hear you on the positions dogs choose to lie in, sometimes it hurts just looking at them, but they like it so they lay in weird contorts.
idahovette
Weiser Idaho
Perry
K20-K10
He used the stick, Andy! Oh and Roger I've cried over my K20 a couple of times!!
idahovette
Weiser Idaho
Perry
K20-K10
Calm down and have a drink.
"Oh, that's your answer for everything!!!"..... Where have you heard THAT before??!!
80BrownK10
Greenwood, SC
Nate
OEM grille:
Aftermarket grille:
Hate to break it to you, walnut is not a very dense wood (when considering hard hardwoods)It's actually
pretty soft. If you don't believe me (as a Forester) just google the density and the hardness scale.
A white oak, or Hickory or hard maple would have been a better choice. But good work though. Dip it in plenty of protective coats and it should last.
jackscott2005
