rebult 3/4 ton axles and blew both front and rear first time out hot rodding
buddy350
El Paso,TX
Buddy
1973 k20
Suburban
1986 Burb with hotrod big block.
Took her out over the weekend for some jumping and drifting at the local off road park.
Blew something in the front axle on the drivers side, make a horrendous sound from the drivers side while in 4wd.
Spent the rest of the day drifting and racing around on some gravel / dirt and exploded something in the rear end.
Thought the 10.5 inch 4.10 rear with 8 lug axles would have been stronger than that.
Kind of expected the front corp to give me some issues.
Now looking for that set of 3/4 8 lug axles that everyone was talking about for 200 bucks.
78C10BigTen
pennsylvannia
Ted
C10 BIG TEN
Souns like ya blew a hub in the front and does the rear have a gov loc? Cool burb tho, i like it
buddy350
El Paso,TX
Buddy
1973 k20
Suburban
Thank you
Rear diff was a limited slip 10.5 inch ring gear.
I had just replaced the spider gears, pinion seal, crush sleeve and outer wheel bearings and wheel seals.
highdesertrange
kalifornia
mike
k30
A limited slip with spider gears? highdesertranger
Loco Hills
K-30
It takes real **** to hurt a 14 bolt full float,unless it has the gov lock or installation error on internals.I didn’t torque ring gear bolts on a 14 bolt after a no spin locker install.Used a 1/2 ratchet and no thread locker.
Luckily,I ran it for awhile and went to change the oil.Every single bolt had backed out.Wouldn’t of been to much longer before it was destroyed.
Anyhow,ran that rear with 37” tires in the rocks,mud and pulled people out with a healthy 383.No problemsIt was out of a junkyard,never rebuilt
The front 3/4 ton is weak in stock form,especially when turning tight in 4WD.Stock GM hubs suck,especially auto hubs.The first thing to go is usually the stub shaft,hub,then u joint.
TubeTruck
East TN
Denis
Suburban K10
LQ9
Check your axles. I bet you blew a u-joint and took out the yoke.
Take the cover off the rear. We want pics! There have been some pretty nasty explosions posted on here lol
buddy350
El Paso,TX
Buddy
1973 k20
Suburban
The spider gears which were purchased new from Richmond only 3 months ago are completely destroyed.
The carrier pin was stuck in the carrier.
We used a cutting torch to remove the carrier pin.
with another set of spider gears and new carrier pin she would be up and going again, but this sf 14 bolt is coming out and a ff 14 bolt is going in.
Here are some photos of the destroyed 14 bolt sf spider gears.
Photo is from 6am cst so it was a bit dark outside but you get the idea of what happened.
DoubleDingo
Right where I am
Bagoomba
Carb'ed Vortec 350
Sparkly
buddy350
El Paso,TX
Buddy
1973 k20
Suburban
True
Not a limited slip.
I misspoke
highdesertrange
kalifornia
mike
k30
that is not a limited slip, that is an open diff. highdesertranger
TubeTruck
East TN
Denis
Suburban K10
LQ9
Nice one! Have you check the front yet?
mick84
