Rear wheelhouses for 1991 suburban square body
Dtrain
New Jersey
Dennis
Suburban R1500
350 cu in
Does anyone know if there are rear wheelhouse patch panels available for the 73 to 91 suburban? Or if someone knows of a donor body?
thanks,
Dennis
There are not. It is one of my biggest pet peeves as a Suburban fan. Despite the fact that they are often the first part of the body to rust out, not a single damn company reproduces them. They also tend to rust out in the "rust free" areas of the country.
Recently, I went so far as to buy a pair or rust-free quarter panels with wheel houses from a seller in Washington. Then when I found out how much shipping was going to be (nearly as much as shipping a truck), I then bought a truck in Washington and had it shipped to OH with the Burb quarter panels in the bed of said truck. It ain't easy, or cheap, finding them, lol.
The other option is to just fab your own out of universal trailer fenders.
Dtrain
New Jersey
Dennis
Suburban R1500
350 cu in
Thanks for the response, I was afraid of that, looks like mr welder will be dusted off and some fabrication will have to be done. I do like your idea of using trailer fenders,as I don’t own an English wheel. I’ve made lots of body panels on my tr3 but they were mostly straight, thanks for the suggestions.
Dennis
R Carnella
Long island
Rich
Suburban V2500
I used the wheelhouse's for the pick-up,they are a little longer but worked out perfect
R Carnella
Long island
Rich
Suburban V2500
Here's a few more pic of getting them roughly in place. They were a lot of work, but no other options really. I bought 4 pieces total,each side has two halfs that bolt together. Inner/outer.
They fit the inside of the quarter panel perfectly and the depth matches up to the cargo floor but the tubs are about three inches taller and 3 inches longer overall.
Drivers side needed to be sectioned to clear spare tire
Anyway it really worked out and from outside looks almost factory. I didn't want to make it seem like they drop in,they don't
You in the operating engineers I see?
R Carnella
Long island
Rich
Suburban V2500
Yes 22 year's.
Does the 3rd row seat still fit with the truck/K5 tubs in place?
R Carnella
Long island
Rich
Suburban V2500
3rd seat fits fine.i regards of seat fitment the wheelhouse is only taller, so seat w/arm rest's fits between no issue. The only other thing that might be a small problem for some, would be reusing original wheelhouse molded carpeting...not sure though because i bought all new carpeting and everything fit fine and looks great. seat belt retractors fit also.
carsenretka
MN
carsen
Suburban
Will any of the truck inner/outer fenders work for this or did you use a specific year? Looks like I may be going this route also. Thanks for the idea!
R Carnella
Long island
Rich
Suburban V2500
73-91 blazer
I used these from lmc truck.
Two main tubs,fits bothsides (38-7612)
You'll need the left and right hand wheelhouse extensions also
(38-7760),(38-7761)
90Supurban
Midwest
D
V1500
I got started down this road and it appears that the inner and outer wheel housings need about 1 inch added between them to reach the quarter panel, as well as being 1.5 - 2 inches too high for the wheel arch, did you have the same fitment challenges?
R Carnella
Long island
Rich
Suburban V2500
That's the one problem I didn't havve. With the old tub flange trimmed away, The width of the new inner/outer pieces bolted together fit well from the inner lip (floorpan) to the inside of the quarter panel.
The "tub flange" that you trimmed away... do you mean the area of the inner quarter panel, where the inside tub and outside tub come together?
R Carnella
Long island
Rich
Suburban V2500
I dug up a pic i had. The trimmed flange i referred to is along the floor pan edge.
In this pic the tub, the tub has been cut out but the remaining flange along the floor pan hasn't been removed yet.
Todd Lemon
