I'm going to enhance the design with a key-switch lockout when internal switch is in use. This is much cleaner to me, and makes a nice clean pack up front and in the tailgate.
The following 5 Diagrams should fully illustrate the setup.
For the Diodes, I will be using a Hella 9-Pin Diode module. It's about the size of a relay.
This makes a very nice clean pack under the dash with only four wires required to complete the setup to the tailgate.
One high current positive
One switched logic current positive
One switched logic current negative
One logic level positive for rear switch (locked out by front relay)
1. All switches in neutral
2. Front Switch UP
3. Front Switch Down
4. Rear Switch Up
5. Rear Switch Down
Note* I had to use two simple motors in circuitJs to illustrate the concept of the suburban's rear motor. There was not a direct matching component for me to insert. Functionally is the same for the flowchart - but an explanation is warranted. The two motors represent the single rear window motor + for Up, + for Down, and Central Ground.
