Rear end sag
79Scott
N37°20’26” - W77°40’34
Scott
C10-Silverado
305ci
Hey Guys,
Just wondering why my Silverado sits low on the rear end? Not sure if that is the factory stance or not and I'm not sure the last time the shocks were replaced. Truck has 76k on it
FireTruck1984
Michigan
1984 and 1984
The rear height looks correct for a C10, Has the front suspension been modified?
Poppy 87
Bloomingdale GA
R10 Silverado
Almost has the stance of a truck with the engine removed
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
The shocks have nothing to do with ride height.
Check for broken or missing leafs.
79Scott
Scott
C10-Silverado
305ci
Truck has plain old shocks on it front and rear. Leaf springs are good...…..
FireTruck1984
Michigan
1984 and 1984
As stated by shiftpro, shocks have nothing to do with ride height.
Must be your springs, an easy solution would be 2” lift blocks. But the right fix would be new springs. It’s also quite possible you have the wrong springs in the front
RoryH19
Rory
R10 Silverado SWB
Definitely looks lower than my 87 SWB. Rake is usually the other way; higher in back than front.
80BrownK10
Greenwood, SC
Nate
Hey Guys,
I'm sure by now someone has posted that shocks do not effect ride height. A worn out set or a new set will not change your stance. Only ones that would would be cool overs or air shocks that are over inflated.
Rangelloz
