Rear end measurement heigth
BBCfan
Edinboro
C10 2WD
My square is a 1976, 1/2 ton, 2WD, long bed. If anyone has a similar truck can you measure the distance between the rear, upper bump stop and the top of the axle housing please? I need this to to set my pinion angle with the ladder bars. TIA, Rick.
78C10BigTen
pennsylvannia
C10 BIG TEN
My truck is a 78 1/2 ton 2wd long box, ill try to get you a measure tomorrow
BBCfan
Edinboro
C10 2WD
Thanks 78C10. If I'm not to late can you also give me a leaf count.
78C10BigTen
pennsylvannia
C10 BIG TEN
Bottom of bump stop to top of axle. And my truck is a big ten wich was heavy duty so may be different but ive got 8 leaves.
BBCfan
Edinboro
C10 2WD
Thanks 78C10. Just what I am after. I'll load it down to 4" as a starting point then recheck after chassis is loaded with all the body parts. I'm only running 6 leafs on mine.
BBCfan
Edinboro
C10 2WD
BBCfan
Edinboro
C10 2WD
20191227_164220
BBCfan
Edinboro
C10 2WD
imyourhuckberry
