rear end help
4speedburb
Waukee
1500 Suburban
ok, so im having an issue with my rear end, and i have no idea what it is, it makes a loud clunking like somthing metal is clunking, almost sounds like a broken u-joint and the drive shaft is hitting somthing. but it only happens when i let off the gas, or press the clutch in while driving. and its pissing gear lube from by the u-joint. any help would be greatly appreciated!
Sounds like a 10 bolt with a toasted pinion bearing. Jack the truck up by the rear axle, with the front wheels blocked. Give the rear of the shaft a good shake and look for movement (like up-down) in the u-joint/yoke/pinion area.
4speedburb
Waukee
1500 Suburban
how would i go about giving the rear end a shake? like lift it up and down? or what
Just grab a hold of the rear of the drive shaft, and give it a shake.
4speedburb
Waukee
1500 Suburban
alright cool!, ill give it a try
Chaz
USA
Chaz
V1500 Suburban
350 tbi/th400/np241c
Hey let me kno what u got cuz my burb also makes a clunking sound when i let off the gas,,,,but its an automatic th400,,,,,
chevydude
arizona
hunt
k20
What axle are you running.
Chaz
USA
Chaz
V1500 Suburban
I have a 3/4 ton 14b sf,,,,,1989 burban 5.7 th400
I'd say U-Joint, but with the spewing of gear oil, Im with bucket and going to say the Pinion bearing has gone bad, and has wallered the bushing and seal at that will explain the spewing of gear oil.
4speedburb
Waukee
1500 Suburban
yup, the pinion bearing is shot, i have all the parts i need to fix it, what tools will i need? and this is my first time doin any rear end work lol
Standard basic hand tools, dial indicator and a magnetic or clamp base for the dial indicator.
HF has a cheap one that seems to work well for the occasional user.
Item #623 $13.99
Item #5645 $12.99
There is also a write up in here by crazy4offroad. Look it up, great info for tackling this project.
J Knight
Baytown TX
82 Chevy
350ci
I'm suprized at the restraint in this thread. Good job.
You're not even lying buddy !!! :happy175: Starting with the title and the first sentence.
aaron06
